Air con not working on a 2010 fg 84 canter
Submitted: Tuesday, Apr 16, 2024 at 17:23
ThreadID: 147540
FollowUps:17
Gary Coutts
Would anyone know where the air con relays are
What are the relays on the left side of the truck behind the cover
The air con does t turn on the light comes on the dash
Cheers Gary
Reply By: IvanTheTerrible - Tuesday, Apr 16, 2024 at 19:38
As a licenced technician most probably it is low on gas but all the A/C experts will be along soon to google and bullshit the correct answer.
645677
Follow Up By: RMD - Tuesday, Apr 16, 2024 at 21:41
I agree with Ivan. If it is low on gas it won't have enough pressure to keep the LOW pressure switch turned ON and so it looks to be ok but the main system won't work.
926013
Reply By: Gary Coutts - Tuesday, Apr 16, 2024 at 20:13
I can get the air con working but not the outside fan and visa versa
Any idea bud
Gary
645679
Follow Up By: IvanTheTerrible - Tuesday, Apr 16, 2024 at 20:59
If you are talking about the fan on the condenser it may only work when required. Those systems are usually installed by the dealerships as a kit. The electrical are usually behind the passenger kick panel or under the grill depending on the model.
What do you do to get one or the other to work?
926011
Reply By: Gary Coutts - Tuesday, Apr 16, 2024 at 21:17
The fuse holder burnt out so a auto sparky put a relay in to by pass the fuse
When I connect up the relay it powers up one but permanently on
Maybe I have the wrong relay or connecting it wrong
645680
Follow Up By: RMD - Tuesday, Apr 16, 2024 at 21:46
That is not a smart idea to bypass a fuse with a relay contacts action. No fuse = burn of something if wiring shorted.
DOES IT COOL AT ALL WHEN RUNNING???? That determines if GAS is OK or NOT.
926014
Follow Up By: Gary Coutts - Tuesday, Apr 16, 2024 at 21:59
There is a inline fuse going to the relay
It does get cold don't let it run for long as condenser gets hot
When I connect OT up to the relay it keeps going g even when I switch of the air con fan and turn of the air con
.makes me think it's not the right relay or my wiring is wrong
926015
Reply By: Gary Coutts - Tuesday, Apr 16, 2024 at 21:19
645681
Follow Up By: IvanTheTerrible - Tuesday, Apr 16, 2024 at 21:32
I assume the fuse was for the condenser fan?
926012
Reply By: Gary Coutts - Tuesday, Apr 16, 2024 at 21:43
Main fuse for air con and fan
645682
Reply By: qldcamper - Wednesday, Apr 17, 2024 at 06:30
Was it working after the sparky gave it back to you? If yes then it is highly unlikley the relay changed itself out for an incorrect one or the wiring somehow jumped onto the wrong terminals.
How much have you blindly swapped about, you have to tell the whole story if you expect to get informed answers.
645684
Follow Up By: Gary Coutts - Wednesday, Apr 17, 2024 at 08:53
Yes it worked after. The sparky put the relay in that was about 3yrs ago
926016
Reply By: Member - LeighW - Wednesday, Apr 17, 2024 at 09:05
It seems to me you are assuming the relay is faulty as you have similar symptoms to what occurred when the fuse failed.
As pointed out other factors can also cause the aircon to not work so if you aren't confident at reading circuit schematics and diagnosing electrical faults it would be a good idea to take it to someone who can as it will most likely save you money in the end.
645685
Reply By: RMD - Wednesday, Apr 17, 2024 at 10:46
Strewth, I am not a dentist, but I can feel what puling teeth is like.
Now we find the RELAY was inserted years ago. Plenty of time since then for the gas to diminish and NOT BE sufficient pressure NOW at static situation, to not even turn on the LOW PRESSURE switch as Ivan indicated previously and other faults to develop with wear, vibration, chaffing of wiring and faulty or loose connections.. I wonder what future revelations will reveal. As QLD said, it is hard to diagnose without knowing much and important factors being presented progressively later, and
well apart in time.
645686
Reply By: ian g14 - Friday, Apr 19, 2024 at 15:18
On our fg84 the ac has stopped mostly 4 times now because of faulty condenser fan relays. bit light duty in box behind lh mudguard identification is on lid inside can swap for horn one to
test to see if fan runs.
check pins for sight of heat or smell realay for hot smell on one occasion cab blower fan stopped was stuck brushes in fan motor under lh dash stripped motor for a look brushes still good at 200000k a bump on the bottom would have done the trick
645699
Follow Up By: Gary Coutts - Friday, Apr 19, 2024 at 22:37
Thanks mate I have had a mechanic look at it out of his league he said gas is full
He thinks it is a short or broken wire behind the dash
The auto sparky in town is uncontactable
The light on the switch comes on but nothing not sure how hard it would be to pull apart and
check out
It has been on rough gravel roads all its life working fully loaded
Good to have someone with common sense reply
Gary
926031
Follow Up By: RMD - Saturday, Apr 20, 2024 at 09:29
Gary
If the mechanic says the gas is full but the task "is out of his league" how does he know the gas situation? DID he run the compressor to see to see if there was a cooling heating exchange happen?
The aircon switch only turns ON a relay to power the system. and another relay and/or thermostat is closed to make the compressor magnet pull in the compressor clutch. If clutch isn't operating and there is sufficient gas, to turn on the low pressure switch, ie, always ON normally, then you are looking for a loos or broken wire or a relay which is sus. The relay which turns on system should click when aircon switched ON.
If the cutch is relay switched from the thermostat, that real opens and closes thousands of times and so may be stuffed. Substituting as others mentioned, would pin that down.
Does the evap/cooling bit inside, ie, the blower fan run? If not it is a main supply issue.
926033
Follow Up By: Gary Coutts - Saturday, Apr 20, 2024 at 09:45
Yes he put guages on pressure is good
When he pit power direct air con works fine nice and cool
There is no clicking when I turn on the air con
Have put all new relays in
Blower fan works fine
Will have to track down a sparky I think
Gary
926036
Follow Up By: ian g14 - Saturday, Apr 20, 2024 at 11:48
Does condenser fan unde lh front wheel work when ac turned on and cab blower working
926039
Follow Up By: Gary Coutts - Saturday, Apr 20, 2024 at 12:04
Yes the in cab fan works not the out side one
If u put power to air con the fan at bottom doesn't work with air con working or power fan air con doesn't work
Tried power to air con and a separate power to fan fan cuts out air con
Have to be wiring fault I think
Gary
926041
Reply By: ian g14 - Saturday, Apr 20, 2024 at 11:55
Relays for ac are in box behind front lh guard on single cab somewhere around there on dual cab
645708
Follow Up By: ian g14 - Sunday, Apr 21, 2024 at 12:50
The fault is most likely condesor fan relay in box behind lh wheel inside lid is printed relay positions could be relay pin connections in receptacle loose or dirty. if you substitute known good relay eg horn relay you can
test have good look atrela pins for signs of bad connection also
check condenser fan fuse also in box or back probe with
test light while still plugged in on top of each side of fuse ac will not function if condesor fan is not working as the condenser gets no engine fan due to mounting position everything else, will work but not cooling
926050
Reply By: qldcamper - Monday, Apr 22, 2024 at 05:14
If it was a condenser fan issue the system would run for a short time then cut out on the high pressure switch usually around 300 psi which the tech would have picked up with his gauges straight away.
I don't understand why it is so hard for a tech to diagnose unless it is fitted with a variable displacement compressor and the control valve is sticky.
645714
Follow Up By: ian g14 - Monday, Apr 22, 2024 at 10:14
No variable compressor on these have had same fault before as he stated condenser fan not running they just don’t cool usually the relay or relay connections condenser is little bugger mounted in front of lh wheel
926065
Follow Up By: RMD - Monday, Apr 22, 2024 at 19:16
The relay which turns ON and Off to control compressor MUST be checked first. It would fail before any other relay, because it cycles so often, ie, ALL THE TIME.
926068
Follow Up By: Gary Coutts - Friday, Apr 26, 2024 at 21:39
Well finally found another auto sparky
It was the thermistor burnt out quick easy fix
Thanks for all the help
Gary
926093
Follow Up By: RMD - Saturday, Apr 27, 2024 at 15:59
How was it a THERMISTOR. They are simply a TEMP SENSING DEVICE and carry miniscule current. ie cannot burn out. However, it may have become faulty and stopped the system switching ON.
926105
Follow Up By: Gary Coutts - Saturday, Apr 27, 2024 at 17:06
It does have a burn mark on it will put a photo on it up if I can
Works
well now $100 fix
Hary
926106
Reply By: Gary Coutts - Saturday, Apr 27, 2024 at 17:16
Thermistor
645744
