Is it possible to concatenate a number of treks in Traveller?
Submitted: Saturday, Apr 13, 2024 at 15:23
ThreadID: 147513
FollowUps:7
Member - davewebby
I have created a number of
treks for an upcoming trip from
Perth to
Darwin. Each has quite a bit of detail with points of interest to stop etc.
Can I join these all together in one to get a single overall trek?
I ultimately want to create a summary plan for our trip to import Google Maps/Google Earth. At the moment I am limited by the number of layers (each trek is a layer) that can be loaded into Google.
Reply By: TrevorDavid - Sunday, Apr 14, 2024 at 06:21
Dave
Yes you can.
Create a folder. Place all of your
Treks and in fact any data you wish into the folder. Highlight / turn on the folders tab in map layers, highlight your newly created folder & all will show on your map.
Have a look at the quick start guide & using maps and data in the help guide. Really easy to do.
TrevorDavid
645664
Follow Up By: Member - davewebby - Sunday, Apr 14, 2024 at 12:28
Thanks, Yes, I have no problem displaying all the
treks in the traveller map (my
treks etc are already orgnanised into a folder). I want to be able to combine these all into a single trek so I can export as a .GPX file and load into Google Maps (specifically the Trip Planner in Google Maps).
925998
Follow Up By: TrevorDavid - Sunday, Apr 14, 2024 at 21:05
Dave
I sent you a member message.
TrevorDavid
925999
Follow Up By: Bonz (Vic) - Monday, Apr 15, 2024 at 17:17
Hey TDB, drop the solution in here too mate, it will interest quite a few members methinks
926004
Follow Up By: TrevorDavid - Monday, Apr 15, 2024 at 20:05
G’Day Bonz it’s been too long mate.
Basically it’s the same as creating any other Trek. Rather than waypoints/
places, you use an already created Trek.
Treks, Personal
Treks, select your starting Trek & swipe left, hit the go to tab, then follow the normal Trek creation process. Then second Trek , third Trek etc. When all the
Treks have been added hit save, name it etc as per normal and it will save in your personal
Treks .
TrevorDavid
926005
Follow Up By: Bonz (Vic) - Monday, Apr 15, 2024 at 20:49
Definitely Trev. Definitely
926006
Reply By: Member - peter g28 - Sunday, Apr 14, 2024 at 20:33
I don't think the ExploreOz Traveller App has the capability to combine all your
treks into a single trek and then export them as a GPX file to another application.
645668
Reply By: Member - Warren H - Monday, Apr 15, 2024 at 09:58
You can combine
treks by opening
treks in order and adding to the end. This can then be saved as the combined trek.
645669
Follow Up By: Member - davewebby - Monday, Apr 15, 2024 at 10:36
Thanks Warren. I eventually figured this out (by accident!). However, when I did this I got a random point out west in the middle of the ocean (which I assume is some sort of map origin point). This in turn screwed up the export of the GPX file (I tried to delete the point - it was marked as an airline symbol - but it just ended up being inserted somewhere else).
I gave up and spent a couple of hours repicking the entire trip into a single trek!
926001
Follow Up By: TrevorDavid - Monday, Apr 15, 2024 at 14:33
Just to add to Warrens post,
After combining into a single Trek, go to Traveller control panel in the website, my personal
Treks, map, then download Trek in the format required. .GPX, .CSV, Oziexplorer or Hema Navigator
TrevorDavid
926002
Reply By: Sidney N - Monday, Apr 15, 2024 at 11:56
This post has been read by the moderation team and has been moderated due to a breach of The Spamming Rule .
Forum Moderation Team
645670
