Toyota 5 stud split rims
Submitted: Monday, Mar 18, 2024 at 18:58
ThreadID: 147279
FollowUps:5
Member - lyndon NT
Hi All
Does anyone know if Toyota 5 stud split rims are still coming on new vehicles?
Chasing some, got the last set, new, off a car for a carton.
I can hear it coming..........................., why do you want those...............etc etc.
Lyndon
Reply By: Member - McLaren3030 - Tuesday, Mar 19, 2024 at 06:42
Hi Lyndon,
Not Split Rims, but they are from a 2021 79 Series Landcruiser Ute.
2021 79 Series Landcruiser wheels and tyres.
645500
Reply By: passionfruit - Tuesday, Mar 19, 2024 at 09:38
No........
645504
Reply By: RMD - Tuesday, Mar 19, 2024 at 14:35
G'day Lyndon.
You must have a specific reason to want split rims. I had some on my HJ61 6 stud and when the tyres wore out Tubeless thereafter. Apart from changing the tyre while still ON the axle, I can't think of any advantage they have.
645508
Reply By: IvanTheTerrible - Tuesday, Mar 19, 2024 at 19:48
Split rims are basically banned now
645514
Reply By: Dean K3 - Wednesday, Mar 20, 2024 at 19:05
Toyota stopped used split rings far back as 2014 observed a newish V8 troopie near
Halls creek in WA and that had one piece rims.
Also be aware that there is a difference between a split rim and a split ring tyre.
Most people call them split rim when in fact they are not. Its the ring that is removed on the older toyota rims. a dangerous thing to work on unless you know what your doing -and inflating was always done inside a wire cage just in case.
645526
Follow Up By: RMD - Wednesday, Mar 20, 2024 at 19:48
G'day Dean.
I used the same words, split rims, too. Although, as you pointed out, it is the ring which is split. Unless the ring and rim groove are impeccably maintained they are dangerous AND because they use a tube they deflate plenty quick, far quicker than a tubeless tyre if punctured. Balloons deflate fast too.
925819
Reply By: Andrew L - Thursday, Mar 21, 2024 at 13:19
I think the v8 was the end of split ring rims, and a guess would be speed rating of tyre.
Many moons ago i carried a spare tube under the rear
seat and a tyre no rim as a second spare. Used both in Tibbuburra after a thorn went through the sidewall.
Replaced by finnileak and tubeless repair kits, alot safer tubeless are, but harder to work on.
With 70's, a 105 rv tubeless 16x6.5 rim has the correct offset to help with track.
645529
Follow Up By: IvanTheTerrible - Thursday, Mar 21, 2024 at 19:48
I still carry a tube as a failsafe. Stopped carrying a tyre when I realized I could no longer break both beads
925824
Follow Up By: RMD - Thursday, Mar 21, 2024 at 21:19
Ivan T T
If you have some tyre pliers you can break any bead , both sides quite easily. Not hard! Years ago, I made a folding device which had a triangle base and an upright section which bolted to it, 2 x 6mm bolts and a levering arm which had a curved swinging section to apply to the tyre bead. Adjustable for different w=rim widths. Pushed them off ok. I do take a trye and the gear to change them if needed.
925826
Follow Up By: IvanTheTerrible - Thursday, Mar 21, 2024 at 21:57
The tyre
shop struggles to break my rear bead. I made myself a breaker and it cant either. Fronts OK but not the rear. At least I can still use a tube
925828
Follow Up By: Allan B (Sunshine Coast) - Friday, Mar 22, 2024 at 11:13
I made a bead-breaker in the form of a 100mm wide blunt 'blade' that attached to the base of my hydraulic or hi-lift jack and placed under the vehicle tow bar pressed down on the wheel laying on the ground. Worked like a charm with almost zero effort and was no larger than the palm of my hand.
Should have patented it!
925829
Reply By: Geoff (Newcastle, NSW) - Sunday, Mar 24, 2024 at 19:36
I have a set of 5 off a Troopy.
Problem is I'm in
Newcastle.
If you look at my Profile picture, you'll see a photo of the vehicle with the rims on it.
They have been in the garage for at least 15 years and are in as new condition.
645542
Reply By: Member - Keith B (QLD) - Tuesday, Mar 26, 2024 at 15:05
I have a safety harness for working on split rims. Made from
seat belt webbing, You are welcome to it if you want.
645553
Reply By: tonysmc - Saturday, Apr 27, 2024 at 11:54
Hi Lyndon, I happened to see the there is a set of 5 stud split rims off a 2015 79 series for sale on maketplace
Darwin if you are still looking? 6 wheels and tyres.
645738
