Used van purchase Jayco expanda or Windsor Rapid
Submitted: Tuesday, Feb 20, 2024 at 18:38
Brett C16
Looking at a second hand poptop caravan between 1400-1600kg Atm. Jayco expanda and Windsor rapid seem to fit my requirements, with space and towing limitations. (VW multivan) Anyone have any experience with either of these vans looking at around 14-15ft, with pop out beds at each end. First impressions is Windsor vans look a bit better build but jayco maybe a bit lighter. Mainly 2001 -2009 models seem to be in budget. Any advise or experience with these models welcome, thanks Brett.
Reply By: Peter_n_Margaret - Tuesday, Feb 20, 2024 at 20:17
My son recently purchased a 17ft Jayco Expanda privately.
He weighed it when he got
home and the empty weight was a tad less than the ATM (like less than 100kg).
DO NOT hand any money over until you get it weighed.
He spent a bundle of $$$$s and gave it aftermarket HD Toyota 90 series rear springs, 3T axle and wheels and tyres that were compatible with his Paj.
It is now a MUCH better van, but KNOW what you are buying.
645338
Reply By: Member - bbuzz (NSW) - Thursday, Feb 22, 2024 at 09:19
I had an early model that went around Australia. 2008?
Leaf springs and double enders. The usual problems with all vans and all easy to fix. Just look at the pop top tensions springs and the screws holding the poptop fabric as rust is the enemy.
Springs can be sand blasted and painted and the screws are replaced with stainless.
I added boxes to the front. See pics.
bill
Van
Rear
Boxes
Rock Protection
Table at the front
Rear view
Inside
Stove etc
645352
Follow Up By: Brett C16 - Thursday, Feb 22, 2024 at 10:00
Thanks Bill, nice van. This is the type of van i am looking at.
925635
Reply By: Best Off Road - Thursday, Feb 22, 2024 at 14:30
Had a Rapid, only went to an Expanda as we couldn't find a Rapid with a shower and dunny. Rapid better build quality, right down to things like zippers and latches. Older Expandas have soft ends which can mean wet pack up. Regardless of which you go with, if you're chasing one with A/C make sure it is a roof mount, they work much better.
645357
