Tuesday, May 17, 2022 at 13:40
Bigfish, define "fit for purpose"?
I have a GVM upgrade done to my PX1
Ranger and I didn't need the GCM increase as well as with our van we're comfortably below GCM, not that it could have happened in the NT anyway back then.
In my experience there's more to a GVM increase than just carrying more load, or a possible GCM increase for a bigger van. There's also the transformation of the vehicle itself.
All vehicles basically come off the production line as a compromise to suit and average market. Comfort becomes more orientated to city use even though those same vehicles are marketed for more extreme use. With our
Ranger the stock
suspension may suit a lot of buyers but personally I found that it was too soft, wallowing, uneven ride height and diving under braking. Even with a load well under it's rating the rear leaf springs were almost flat, no arch, let alone loaded for touring and a 260kg ball weight. All within Factory limits.
So if this is a case of unfit for purpose then what are the alternatives? I could go to an LC200/300 or the RAM 1500 and its equivalent's but taking a good look at them they fall short as their payload capacity without a GVM increase is less than our
Ranger. Although they can actually tow the rated 3500kg it's when you take off the probable 350kg ball weight that they are really likely to be just as illegal when towing. Going to an even bigger tow vehicle is out of the question for most users.
As to our
Ranger with a GVM upgrade, it's transformed the vehicle as it now has a level ride height left to right, far less diving under braking and far more stable on the road with undulations, cross winds or passing road-trains etc. The only compromise is the ride height increase and ride harshness, but both are a non issue to us. I did for a period try just an extra leaf in the rear and Bilstein shocks all round but that just exposed more the front spring softness when not hitched to the caravan. A properly matched GVM kit does wonders, in my experiences.
These vehicle types are marketed as off-road capable and for caravan towing but in their standard form they aren't really capable of the wide customer usage that they are sold for. In fact you can option them with GVM upgrades at point of sale so that's an admission that these modifications are Manufacturer approved for "better fit for purpose".
919650
