unable to load image in Ozi for Android
Submitted: Wednesday, Sep 09, 2020 at 17:26
883robert
G'day. Been trying to swap over to Ozi Android for field use but am having trouble loading maps. I calibrate an image in Ozi on my pc but when opening the .map file on my Samsung tablet running Android 9 I get an error message 'Unable to load image'. Screen grab is attached, as is the .map file.
irishtown RGC.map
The image file is a 2.5 MB png file and it loads fine on my pc.
Does anyone have any idea what I'm doing wrong?
Thanks in advance. Rob
Reply By: Frank P (NSW) - Wednesday, Sep 09, 2020 at 17:45
Ozi grab.jpg downloads as a .map file named Ozi_grab_jpg.map.
I tried changing the extension to .jpg and also to .png, but neither worked on my Win10 PC with any of the graphics progs I have. All reported some kind of header error or file corruption or file format not recognised.
633349
Follow Up By: 883robert - Wednesday, Sep 09, 2020 at 19:05
That's an idea Frank. I'll convert the image to another format and calibrate that. Just to clarify, did you change the file extension without changing the file format?
910358
Follow Up By: Frank P (NSW) - Wednesday, Sep 09, 2020 at 19:48
I presumed that Ozi grab.jpg was supposed to be a screenshot and therefore would be an image of some sort. So I just changed the extension.
I did not try to change the file format.
910359
Follow Up By: 883robert - Wednesday, Sep 09, 2020 at 19:57
You're right, the image file I attached was just a screen grab. I'm now attaching the actual image file that Ozi is meant to use.
Regards, Rob
irishtown RGC.map
910360
Reply By: Phil G - Wednesday, Sep 09, 2020 at 19:52
From the Ozi for Android website:
"The image formats jpg and png (small maps less than 20MBytes uncompressed) are also supported but are fully loaded into memory so the images must be small and only 8bit and 24bit color formats are supported. It is highly recommended maps in jpg and png format are converted to OZF4 using the Img2Ozf conversion software."
633353
Follow Up By: Phil G - Wednesday, Sep 09, 2020 at 22:20
And second suggestion, have you Indexed the maps after adding the file?
Main Menu --- Operation ---- Map ---- Index Maps
910364
Reply By: SCUBADOO - Wednesday, Sep 09, 2020 at 20:16
As Phil mentioned PNG files really need to be converted to .ozfx format for speedy and reliable opening in OziExplorer for Android.
I have attached your map sourced from my existing collection. Unzip the 2 files and Ozi will open the map.
Neville - NZ
Ozi Irishtown
633354
Reply By: Member BarryG - Thursday, Sep 10, 2020 at 10:05
Regardless of the actual format of the file containing the map image, its name must be exactly the same as in the third line of the .map file.
Barry
633359
Follow Up By: 883robert - Thursday, Sep 10, 2020 at 11:34
Thanks everybody, you've answered my questions and solved my problem. I can now load my files on my tablet as long as they're in ozf format. I don't understand why png image files didn't load but that's not important to know. I was testing them for someone else, whom I'll now advise to stick to ozf format.
All good and thanks again.
Rob
910373
