Fiamma F45 awning not stayingclosed during travel
Submitted: Tuesday, Sep 08, 2020 at 13:45
Trevor G5
Hi, we've just returned from a 2000k trip and the awning works its way loose like .5 cm on the front. Its nothing drastic but annoying. Just wondering if someone knows how to tension it so it stays completely closed all the time. Thanks Trevor
Reply By: Member - McLaren3030 - Tuesday, Sep 08, 2020 at 15:07
Hi Trevor,
Can you post a photo of the awning in it’s closed position? Might be a bit easier to advise if we can see a photo.
633339
Reply By: terryt - Tuesday, Sep 08, 2020 at 16:23
Wind it right out and give it a bit of a tug on each side to make sure it's out as far as possible. Then wind it in. Worked for me
633340
Follow Up By: noggins - Tuesday, Sep 08, 2020 at 18:44
Then leave it in the wind up lever position. not the unwind release position.
We do this with ours and it stays tight against the side of the van
Ron
910353
Reply By: PeterInSa - Tuesday, Sep 08, 2020 at 20:13
Trevor, Did the Fix on our Fiamma on our Sprinter Campervan sometime ago it was probably like the Youtube below, but from memory ours was on the rear end of the awning.
https://www.youtube.com/watch?v=vY3NubzC29k
633341
Follow Up By: Trevor G5 - Wednesday, Sep 09, 2020 at 06:25
Thanks, I had a look at the front like the YouTube video had and could not see the adjustment there when I was on the road. I will have a look at the back today. Thanks for the information.
910355
Reply By: Mark C9 - Wednesday, Sep 09, 2020 at 11:14
I've always been concerned that the awning could fly open at speed like a big sail
I use a 50mm wide piece of Velcro wrapped tightly around the arms – just in case
633345
Reply By: Member - Warren H - Wednesday, Sep 09, 2020 at 16:56
We are also having issues locking the awning closed, especially with a wet pack-up. I'll look at the video with interest. Fiamma also have a trouble shooting doc.
Fiamma trouble shooting guide
633348
Follow Up By: Trevor G5 - Thursday, Sep 10, 2020 at 13:37
Thanks, thats helpful information. I'm going to try this when the weather is a bit kinder. Thank you.
910377
