Fj 40 Diesel Conversion
Submitted: Sunday, Jan 26, 2020 at 21:07
Big Daddy 69
I’m looking at buying pre 74 40 series’ with a 1f, just wondering what conversions are out there to change it to a diesel? And if anyone has done it before? I’ve developed a bit of a list just making sure what I’m in for! Thanks!
67 40 series with Holden 253, possible option
Reply By: Ozhumvee - Monday, Jan 27, 2020 at 06:43
The diesel drivetrain from a later model FJ45 or 47 should pretty much bolt in.
The best Toyota diesel to put in would be the 1HZ motor out of a 75, 80 or 100 series, they are all six cylinder and Toyota never put a four cylinder in a 45 or 47 in Oz.
Either of those engines would need a rebuild at this stage in life unless you are lucky enough to find one that has been already done.
629734
Follow Up By: Big Daddy 69 - Monday, Jan 27, 2020 at 17:12
I was thinking a H/2h/12 ht as I like them more but thank you for your suggestions!
What is your idea surrounding the drive trains?
Thank you!
904819
Reply By: Mikee5 - Monday, Jan 27, 2020 at 08:22
I actually had this done. Fitted a B series engine to a 1976 FJ40 in about 1980. It was done by Kiewa Valley 4WD in Victoria. They changed engine mounts including a custom mount for the rear of the transfer case. Not sure of the rest. They were against fitting a 6 cyl due to weight and balance of the shorty. In all it was a good conversion. Bear in mind you have a classic or collectable vehicle and will probable seriously reduce its value by doing this.
629737
Follow Up By: Big Daddy 69 - Monday, Jan 27, 2020 at 17:24
Makes sense, any regrets? How did you go in terms of rego? Mind you times have changed ahah. Thanks mate!
904820
Follow Up By: Batt's - Wednesday, Jan 29, 2020 at 07:44
But they came out with a 6 cylinder petol I had a 1975 petrol shorty no issues so what's the weight difference with a diesel. Also remembering people fitted a bullbar and a winch without weight and balance issues you speak of.
904877
Reply By: Mikee5 - Monday, Jan 27, 2020 at 08:23
Just looked at the picture, that is a 45, not a 40 so ignore my post haha.
629738
Reply By: 9900Eagle - Monday, Jan 27, 2020 at 09:11
Have a look at installing install a 12HT engine if you can get your hands on one. They are a much better than the H or 2H and better power than a 1HZ and the H motor will rattle your teeth .The 1HZ will have the intake and exhaust manifold on the other side + radiator piping, starter motor and auxiliaries ie alternator vacuum pump and air cleaner, then an adaptor plate would have to be used to couple the bell housing.
629739
Follow Up By: Big Daddy 69 - Monday, Jan 27, 2020 at 17:26
Yeah I am looking at the earlier ones, I’ve found a few nice 12hts with a $6000ish price tag . Thanks for your help!
904821
Reply By: Bob Y. - Qld - Monday, Jan 27, 2020 at 09:31
Have seen one with a Cat 3208 engine in it!
Cat Power.
As
well as the 12HT Eagle mentioned, the 1-HDT would be a good choice. Toyota reliability(once the big end issue was sorted), Turbo power & no electronics, like the later versions.
Have seen an F-100 with a small Cummins 6 in it. The Ford Barra motor is popular, but you're dealing with electronics then.
629740
Follow Up By: 9900Eagle - Monday, Jan 27, 2020 at 17:55
Hell Bob, with that truck engine you would have to stick a couple of 5" stacks on it. LOL
Good to see you are getting some rain, I see Lake Julius is 92% and rising and the Curry is flowing.
904823
Follow Up By: Big Daddy 69 - Monday, Jan 27, 2020 at 18:05
Any idea what he had changed on it? Thanks Cob!
904824
Follow Up By: Ron N - Tuesday, Jan 28, 2020 at 17:42
To fit a Cat 3208 V8, you would need to strengthen the chassis and front axle, and install custom-made springs and strengthen the spring perches.
Then there would be a major braking system upgrade needed to stop it.
A 3208 weighs at least 750kgs, that is a serious increase in weight of about 420kgs over any Toyota 6 cyl diesel, and 390kgs heavier than the Toyota 1VD-FTV diesel V8.
I don't understand how you could actually get a 45 Series Toyota registered with a Cat 3208 fitted.
I've seen an F-350 Ford with a 3208 fitted, it was a shoehorn fit, and it was very front heavy.
Cheers, Ron.
904862
Follow Up By: 9900Eagle - Tuesday, Jan 28, 2020 at 17:58
Ron to add to the list of mods, you would have to replace the drivetrain as
well, from memory a low rated 3208 was about 800nm of torque.
904864
Follow Up By: Bob Y. - Qld - Tuesday, Jan 28, 2020 at 20:55
I haven’t eyeballed the vehicle, so don’t know what mods have been done with the transplant.
Tidy ute.
Ron, you might be able to find the owner & find out the specs?
Some good rain around the west, about 120mm in
Winton, and even higher falls south of town. Good start, albeit a slow one.
904869
Follow Up By: Ron N - Thursday, Jan 30, 2020 at 19:14
Hi Bob - Yes, that 45 series traytop with the Cat 3208 appears to be carrying a Boddington number plate, so it may be possible to track it down - although it could take a while.
I used to own a
farm between Boddington and Wandering, and there were quite a few "revheads" in the area!
Cheers, Ron.
904916
Reply By: tonysmc - Monday, Jan 27, 2020 at 10:26
I'd contact Marks4wd adaptors, they seem to have conversion kits for everything.
A old friend put a 5 speed in his 40 series and that made a huge difference. It was diesel but I cannot remember if converted it to diesel or not. It was a long time ago and I think diff ratios may have to be changed as
well if going from petrol to diesel (5 speed conversion may negate this?) He didn't use the company above but I'm sure they'd know the issues
629741
Follow Up By: Big Daddy 69 - Monday, Jan 27, 2020 at 18:07
I tired them before but no luck, I think I’ll try them again!
904825
Reply By: swampy - Monday, Jan 27, 2020 at 19:09
hi
4cyl diesel factory turbo ,, 3.5ltr ?. Fairly sure u can buy them as import motors
2h factory tubo
1hz factory turbo 2 versions
629752
Follow Up By: Gbc.. - Wednesday, Jan 29, 2020 at 09:40
"4cyl diesel factory turbo"
13BT 4 cyl?
Roothy's
Milo has one so you'd find a few online articles to give hints as
well. Being a light truck engine you'd have to gear it down to stop it revving on the highway. It would be a good match with a disk brake front end conversion.
904883
Reply By: Member - DOZER - Wednesday, Jan 29, 2020 at 15:14
Gday, keep in mind you will need to engineer most of the conversions, if your year model didnt come diesel. I cant remember when the 1h started being used. My sons mate put a 12ht in his fj45 and had to take it back out for this reason.
I have seen the dyna 14b motor used in the shorties, which were 3.7 litre direct injection and thesame to look at as a 3b, so theoretically, a drive train available from a wrecker would bolt straight up.
629786
Reply By: Batt's - Friday, Jan 31, 2020 at 22:31
The 12HT is a great motor plenty of power and fitted with a 2 1/2' exhaust to let it breath they run
If your looking at a 4cylinder why not go a bit more modern and fit a Hilux motor instead of the old 13B something like the 1KD-FTV which has more torque and power.
629837
Reply By: Michael ( Moss Vale NSW) - Tuesday, Feb 04, 2020 at 11:44
Sorry i cant help with the diesel, but a wide range of engines have been fitted to these. I had a mid 70s, 40 series as a
farm truck when i had acreage in the Southern Highlands NSW and it had a Ford 250 cu in six fitted and it was a power house. It was in great condition, i wish i had kept it. Regards, Michael
| Patrol 4.2TDi 2003
Somewhere you want to explore ? There is no time like the present.Member My Profile My Blog Send Message |
629883
