Dual rear wheel query
Submitted: Wednesday, Aug 21, 2019 at 14:31
terryt
Have a Toyota Coaster and it is impractical to carry an extra spare. If worst came to worst could you drive with only one wheel on one of the rear duals
Reply By: Bob Y. - Qld - Wednesday, Aug 21, 2019 at 16:54
As long as the nuts will do up tight with only one wheel on, you should be right, Terry.
The Toyota trucks from ‘60’s & ‘70’s had 2 wheel nuts on each stud on rear wheels, so you could safely run one wheel on either side, depending on weight issues. The inner “nut” was threaded on inner & outer surfaces, and a large hex nut screwed on this to lock the outer wheel flange. Not sure if the Coaster has a similar arrangement?
627368
Follow Up By: terryt - Wednesday, Aug 21, 2019 at 17:38
Yes it does Bob. Thanks. Hope it doesn't happen but it does give an option
901338
Follow Up By: Member - Harry C - Thursday, Aug 22, 2019 at 06:59
Not sure but seem to rember LH threads on the left side wheels.
901344
Follow Up By: Member - Neil T6 - Saturday, Aug 24, 2019 at 08:05
Absolutely what Bob Y says. There must be heaps of
farm trucks out there with just one wheel where there would have originally been duals. Very common in rural areas.
901382
