Recording trip details on a map
Submitted: Wednesday, Aug 21, 2019 at 13:01
Member - John
G'day, having been advised about the search function, not sure if I am using the right words or not but can not find anything. I wish to have a map of Oz with my trip details on it, not tracking as such, as I visited a lot of
places before I got my SPOT tracker. I wish to plot old trips and
places visited, also it has to work on a laptop not a smart phone. Has anybody got such a program that is easy and user friendly. TIA.
Reply By: Member - Stephen L (Clare SA) - Wednesday, Aug 21, 2019 at 14:07
I use and highly recommend OziExplorer.
With your maps loaded, you can then see where you want to go and where you have been and great for trip planning.
If you connect it with a GPS, either, Bluetooth, GPS mouse, hand held or what ever, it will record your travels and give you real time mapping as you drive and then you can do many things after that.
You will no doubt get lots of answers, but for me, OziExplorer will not let you down and I have used it out in the field for around 19 years.
627363
Follow Up By: Member - John - Wednesday, Aug 21, 2019 at 15:00
Stephen, wanting to plot
places visited in the past, use SPOT to track current trips, wanting to put all the trips on one map, the map attached is from a app called Trackmytrip, but only works on smart phones, which I don't have.
trakmytrip map
901333
Follow Up By: Member - Stephen L (Clare SA) - Wednesday, Aug 21, 2019 at 15:24
OziExplorer will do everything you want and a lot more.
I always save every track that we drive, and any important waypoints along the way.
The only trouble with SPOT (yes I know what they are and also use a SPOT 3)
is that the data is only recorded every 5 minutes in my case. When you look at the data that it collects, either on SPOTWALLA or on
the SPOT page, you never get nice clear lines on a map.
The image below is from OziExplorer with the
EOTOPO 144k map loaded. The blue lines (this colour I selected, but you can customise what ever colour you want) are the actual path that I drove and recorded by OziExplorer and all those yellow squares with numbers are the waypoints that I recorded.
The area is around the
Oodnadatta Track area and
Coober Pedy. when you go in at 100%, you will see even more data.
So from these images, you will not get any better than this type of track recording.
OziExplorer at only 5%
Same map, same data, but at 100%
901334
Reply By: ExplorOz Team - Michelle - Wednesday, Aug 21, 2019 at 15:13
Manually creating a trip you've done in the past, is just the same as creating a route for a trip you intend to do - ie you are not using live recorded data. What you are asking for is a trip plan routing tool.
This feature does exist in our app
ExplorOz Traveller - which is available for Windows 10 laptops so perhaps this is worth looking at.
627364
Follow Up By: Member - John - Wednesday, Aug 21, 2019 at 17:51
Michelle, thanks, once again as I am a technological troglodyte, WIN 7 here only.
901339
Follow Up By: ExplorOz Team - Michelle - Wednesday, Aug 21, 2019 at 18:49
Understood - just be aware that Win 7 reaches end of life in January 2020, which means no future security updates or fixes so you will be at greater risk for viruses and malware. I know you feel like you're not technical but going forward, the best way for you to stay secure is on Windows 10 otherwise you are just making things worse for yourself. Otherwise, ditch the PC and stick with a phone/tablet that does everything in the one device to save money and keep it simple.
901341
Reply By: Sand Man (SA) - Wednesday, Sep 04, 2019 at 10:08
Another fan of OziExplorer.
I record my trip for reference purposes and nothing else comes close for accuracy.
I also use ExplorOz Traveler and Spot Messanger, both linked back to my EOTrackMe profile, but the abbreviated recording positions show a series of straight lines, rather than a continuous track like OziExplorer does.
627565
Follow Up By: Frank P (NSW) - Wednesday, Sep 04, 2019 at 12:34
In my experience,
ExplorOz Traveller records a continuous track like OziExplorer. It is possible to see a series of short straight lines if you zoom into magnified street detail, but for the purpose of recording your travels on a map it is more than adequate - plus its other uses and features, of course.
Here's an example:
Recent trip
901639
Follow Up By: Member - ACD 1 - Wednesday, Sep 04, 2019 at 13:21
Example of same trip recorded on two devices on the same day. One a Spot Gen3 with (1.5 min recording intervals) the other an iPad running
Exploroz Traveller App.
Spot Capture
ExplorOz Capture
You can see the difference in the recording of tracks at Zoom 15. ExplorOz follows the actual road.
Anthony
901640
