Rear draws vdj76
Submitted: Saturday, Feb 16, 2019 at 15:19
B1GDOG
Guys , am looking into rear draws . Super centre has what looks ok draws . Need them cheap at min . Money going to exhaust and rear Eaton . Just need somewhere to hold gear . Question is how do you work out draw size , or what is draw length for a 76 . So as I can order an get delivered to my door . Cheers Brian
Reply By: Shaker - Saturday, Feb 16, 2019 at 16:30
Couldn’t you work it out with a tape measure? Just measure the available space & cross reference with the dimensions of your preferred retailers drawers.
623893
Follow Up By: B1GDOG - Saturday, Feb 16, 2019 at 17:39
Mate was hoping to get a “100 series fits “ something so simple . Tape only cuts it for draws . It’s the wings ..... these units aren’t made for vdj76 . They do 80, 100,200’s . I’m in the dark . Was hoping for , bolts in an drive away . Ain’t happening Jan ...... I can’t afford the next lvl in draws $1500 . Need my Eaton locker first . Cheer Brian
897219
Follow Up By: Shaker - Tuesday, Feb 19, 2019 at 22:15
I think Adventure Kings drawers can come with a generic wing kit that just needs trimming to fit. I didn’t think you mentioned wings in your original post.
897340
Reply By: wooly0005 - Sunday, Feb 17, 2019 at 01:13
Hi Brian,
The Titan drawers are like a one size fits all I think. Just tell them what model you want them for and you get the drawers and a set of side wings to suit.
Quality is reasonable but so is the price. (You get what you pay for)
They are very heavy though at 75kgs so this will contribute to GVM issues.
623903
Follow Up By: B1GDOG - Sunday, Feb 17, 2019 at 10:43
Thanks wooly . Like I thought . They don’t make a the wings for the 76 . Yes draws are easy , it’s the wings ,to get them to match . Will ring to order . Think airbag rear is needed , the weight is one I didn’t pay attention to . Thanks for slapping me in the face an waking me up . Lol ?? cheers Brian
897238
Follow Up By: Kazza055 - Sunday, Feb 17, 2019 at 19:15
I had the Outback Drawers installed into my D-Max as part of the initial purchase, the cost a ship load more than the Titan drawers but they do come complete with side wings to suit.
If I was doing it again I would have no hesitation in going the the 4WD Supacentre products, they appear to be made just as
well as the Outback drawers, same bearing / runner setup and look just as solid.
Once you have them fitted it would not take much to fill the sides in.
Agree with wooly0005 comment regarding the weight, I ended up needing to have the GVM upgrade done but then I also have long range tank, bullbar canopy dual battery etc but it all adds up.
897253
Follow Up By: LAZYLUX16 - Sunday, Mar 03, 2019 at 10:13
Kazza055 I have Outback draws really
well made tough as nails lucky picked up nearly new for $850.
897563
Follow Up By: nickb - Sunday, Mar 03, 2019 at 21:42
I have the 1300mm long Supacentre draws, they weigh 99kg. Bearings needed some slight adjustment from new but now the drawers slide perfectly. Also, they only open up about 2/3 of the way so access to the gear at the back of the drawer can be limited.
897572
Reply By: Member - Trouper (NSW) - Tuesday, Feb 19, 2019 at 12:12
Not sure where you are B1GDOG , was at Off Road Systems at Smeaton Grange (near Narrellan NSW) couple of months ago and they were fitting up a 76 series with draws and wings. Try them they are very helpful and willing to give advise. They have been doing 4wd fitouts for about 20 years.
Jeff
623973
