Wind screen cleaner
Submitted: Monday, Jun 25, 2018 at 13:38
chris a
Good/day
I know this may seem a stupid question, But there is something on the inside of window screen of my new second hand SR6.
It dose not seem to lift off the screen It like a glue
IT just smears around, I have Tried a lot of things
Please help me with this one
Thank Chris
Reply By: RMD - Monday, Jun 25, 2018 at 13:58
Try and use vinegar, it is an acid and cleans many things quite
well. Inside of glass is nearly always a build up of formaldehyde evaporated out of the vinyls and
seat trims.
You know that lovely new car smell which people seem to like, it is only poisoning you a little bit.
619785
Follow Up By: chris a - Monday, Jun 25, 2018 at 14:09
Thank Mate will try it right now
892106
Follow Up By: Kazza055 - Monday, Jun 25, 2018 at 16:07
A simple and quick way to remove grease is to put some diluted baby shampoo in a spray bottle.
892110
Follow Up By: Member - Cuppa - Monday, Jun 25, 2018 at 19:32
Possibly a type of adhesive/goo used to try to get a suction pad to stay on the windscreen in hot conditions? I used a clear pad from Mr Stickee at one stage & when I removed the dash cam I left a difficult to remove goo possibly like you describe. Pretty sure that eucalyptus oil made short work of it, so perhaps try that if other suggestions fail.
892120
Reply By: Ron N - Monday, Jun 25, 2018 at 21:55
Citrus oil works for me, when there's a need to remove gummy adhesive coatings.
De-Solv-it, Sticky Spot and Stain Remover, 125ml bottle from Bunnings.
Oomph Glue and Stain Remover 500mL from Bunnings or Officeworks (cheaper at Bunnings).
Orange Power Spot & Goo Remover 110ml bottle from Woolworths.
Cheers, Ron.
619792
Reply By: CSeaJay - Tuesday, Jun 26, 2018 at 13:43
I'll add Eucalyptus oil to the list
Works
well on removing stickers and the sticky residue they leave as
619795
Reply By: Robyn C8 - Wednesday, Jun 27, 2018 at 21:12
Just be careful with what you use, if you have window tint (after market)..
Home brand window cleaner is ok to use on tint..
If no tint...as mentioned.Eucalyptus oil is great!.. Just be persistent
619819
Follow Up By: Alloy c/t - Sunday, Jul 01, 2018 at 14:55
Yep , if you have any 'aftermarket' window tint you should use nothing but what the tint installers use , that being clean water with a 10% metho mix .....
892221
