KML file into ExplorOz App?
Submitted: Tuesday, Jun 19, 2018 at 14:21
Duncan2H
Previous threads (over a year old) suggest that its not possible to get ExplorOz to display a route/track contained within a KML file..
Is this still the current advice?
Reply By: ExplorOz Team - Michelle - Tuesday, Jun 19, 2018 at 15:19
The app does not support importing of external files, no.
However, if it's of any help, you can create Private
Treks in-app, and the app comes with the 182 ExplorOz
Treks already built - which you can use as-is or modify (save as new Private Trek) to suit your needs. These are the same 182
Treks that you see published on the website with the difference that the app will actually navigate you along the route.
619684
Follow Up By: Duncan2H - Tuesday, Jun 19, 2018 at 15:24
Thanks Michelle..
I have found an ExplorOz "User Trek" that is pretty close..I'll try downloading it to my device tonight.
Cheers, Duncan.
891971
