OBERON AND REGION
Submitted: Wednesday, Apr 11, 2018 at 17:43
Member - reggy 2 (VIC)
I wish to travel up to
Oberon from Goulbourn with a 21ft caravan then up to
Lithgow or up to
Bathurst my concern is a overhead
rock formation ,can anyone give me the coordinates for this structure please.
Also is the road suitable for a 21ft van.
Cheers Reggy
Reply By: Michael H9 - Wednesday, Apr 11, 2018 at 19:13
I can't recall an overhead
rock structure on the road from
Goulburn to
Oberon and I've done the road quite a few times. Are you thinking of the tunnel on the
Wombeyan Caves road? That road is really not suitable for a van. The main road from
Goulburn to
Oberon is a nice road, tar all the way with a couple of switchbacks down near the river. Ok for a van in my opinion.
618228
Reply By: Member - Howard (ACT) - Wednesday, Apr 11, 2018 at 19:30
hi
cliff,
road from Goulbourn to
Oberon is no problem ,all tarred, has been for a few years.
no overhangs on this bit but a total of about 6-7 km of a very steep and twisty decent into then a steep climb with a couple of switchbacks out of Abercrombie
River crossing.
while not recommended for caravans and semis we have had 4 decker stock floats bring stock thru that way.
there are some overhangs on the road from Jenolen Caves to
Oberon but you needn't be there.
Oberon to
Bathurst no issues
Oberon to
Lithgow- we normally travel via Tarana and then towards LakeLyall and then into
Lithgow
this is a skinny road with a few steep sections and a couple of 1 lane bridges over the railway line.but all tarred and doable
if you want to go north of
lithgow ie Cullen Bullen,
Capertee you turn left and head via Rydal( rather then right to lake lyall) then onto the highway near Wallererwang turnoff. again skinny twisty tarred road but quite doable.
hope this helps
regards
Howard
618230
Reply By: Athol W1 - Wednesday, Apr 11, 2018 at 19:31
Reggy
I have towed a 21ft van on that road without any issues, so long as you drive to the conditions.
There is a long steep drop into the Abercrombie
River crossing which is best taken in a very low gear (1st in my case) so as not to overheat the brakes, and then a similarly long climb out again, but as long as it is approached with caution you should not have any problems.
The only over head
rock formation that would/could be an issue that I know of in the area is the tunnel on the dirt road from Mittagong to
Wombeyan Caves
Regards'
Athol
618231
Reply By: Member - reggy 2 (VIC) - Wednesday, Apr 11, 2018 at 19:39
Thanks people that has to be the tunnel on the Wombeyan road that i was thinking of, thanks also for the road report.
Cheers Reggy
618232
Follow Up By: Malcom M - Thursday, Apr 12, 2018 at 09:58
Although that road is not recommended for caravans, 100's use it each year anyway.
I'd sure hate to be backing one up after encountering a fallen tree (which happens fairly often).
I've also head on encountered a semi on that road with a monster bulldozer on the trailer. That was interesting...
890170
Follow Up By: Frank P (NSW) - Thursday, Apr 12, 2018 at 12:59
I also encountered an opposite direction semi, and I was towing a camper trailer. That, too, was interesting.
890179
Follow Up By: Gronk - Thursday, Apr 12, 2018 at 19:15
Went to Wombeyan 2 weeks ago with a small van....late arvo going in was OK, but Sunday lunchtime coming out we met 17 vehicles going the other way......certainly keeps you on your toes..
My van is only 2m wide, but a big van wouldn't be my idea of fun ??
The tunnel.....no problems with room thru there .
890194
