Waeco CF40 fridge 240volt fault
Submitted: Saturday, Feb 10, 2018 at 19:14
Richard S18
Waeco Woes
I have an older (13 years) CF40 Waeco fridge with the older non digital temp display and have a failure of the 240volt operation. When switched on to 240v it makes a loud cracking noise and does not operate. It works currently OK on 12v so the compressor is OK.....I previously had a lot of issues with the 5 second flashing light fault and had a local techo fit a larger 9amp resistor or similar. Worked fine on the
Canning Stock Route last July and did not use it for months until a week ago when connected to 240V.
Any one able to suggest what the issue is as I am able to fit a new part if it can be identified presuming they are saleable still.
Cheers RichardS18
Reply By: HKB Electronics - Sunday, Feb 11, 2018 at 10:35
Crackling does not sound good, could be arcing is there any burnt smell?
Haven't looked at one o don't know how there set up, it might have a surge suppressor that's is causing the crackling sound. Can you post up a picture of the PCB?
616810
Follow Up By: Richard S18 - Sunday, Feb 11, 2018 at 17:33
thanks for the follow up HKB Electronics.
...was a slight burn smell initially ..... when I opened up and looked at all the boards no sign of arcing or burning unless the power cord is shorting.
The internal unit which has the positive , negative and 5 other wires in a line was not easily accessible for photos etc.
A mystery so far......but am determined to fix it as it is such a waste to throw away for probably a more inferior one.
888254
Follow Up By: IvanTheTerrible - Sunday, Feb 11, 2018 at 17:39
Buy an appropriate 240v to12v power pack an forget the internal 240v altogether.
888256
Follow Up By: Richard S18 - Monday, Feb 12, 2018 at 10:53
Thanks Ivan it may end up being the best and most cost effective option.
Cheers Richard
888272
Follow Up By: Allan B (Sunshine Coast) - Tuesday, Feb 13, 2018 at 18:02
Richard,
Ivan's suggestion of using an external power supply has merit.
As it happens, Seabreeze Industries (a reliable business) has just advertised a Dometic (Waeco) 240vac-12vdc 6 Amp power supply for $39.99 del free. Normally $99.
Link here to Seabreeze then click on "Special Offers".
888310
Follow Up By: Member - Rod N (QLD) - Tuesday, Feb 13, 2018 at 18:48
I did what Ivan suggested. I have a Waeco power pack from a previous non 240v fridge. Of course powered by 12v while travelling.
888315
Follow Up By: Richard S18 - Tuesday, Feb 13, 2018 at 18:52
Thanks very much for that Alan. I will
check them out and see if my model is suitable as it is an older non digital with a led display and turbo option which draws a bit more juice so have to make sure the draw is suitable for the inverter.
CHeers Richard
888316
Follow Up By: Allan B (Sunshine Coast) - Tuesday, Feb 13, 2018 at 19:39
Richard,
The power supply I referenced is rated 6 Amps continuous.
If your old Waeco draws more than 4A I would use it as a boat anchor! lol
Incidentally, do you perhaps have a battery charger with "Supply" option?
That is what I power my Waeco with at
home.
888318
Follow Up By: Richard S18 - Tuesday, Feb 13, 2018 at 20:06
Yes thanks for that Alan....I. have some good leads to follow up on.
Cheers Richard
888323
Reply By: Allan B (Sunshine Coast) - Sunday, Feb 11, 2018 at 13:43
Hi Richard,
This product was the subject of a
recall in December 2016.
The recall said "If the failure occurs it may cause the controller to overheat and partially melt, becoming a burn risk to consumers." It sounds rather like the condition you described.
Obviously, do not again try to connect it to 240v until it has been attended to, although there should be no problem to using it on 12 volt.
The 240v module can be replaced but if you are not able to identify the problem and that module then I would not recommend that you try to replace it yourself. Obtain competent assistance.
616814
Follow Up By: IvanTheTerrible - Sunday, Feb 11, 2018 at 16:39
Are you sure a 13yo Waeco was recalled in 2016? I think that was the later Dometic type not the earlier version
888252
Follow Up By: Richard S18 - Sunday, Feb 11, 2018 at 17:38
Thanks Alan for the reply and advice. I am wary of replacing 240volt parts.
I agree I think the recall was for the newer models as Ivan has said but I will
check the Waeco website to make sure.
Cheers Richard
888255
Follow Up By: Allan B (Sunshine Coast) - Sunday, Feb 11, 2018 at 17:43
You are quite right Ivan. I phrased that badly.
The point I was making was that a 'similar' product was "the subject of a recall etc."
Meaning that it could be a similar failure.
My other comments still apply though.
888257
Follow Up By: Richard S18 - Tuesday, Feb 13, 2018 at 18:48
Thanks to all the people who were kind enough to respond.
Have spoken to the repairers EDIS in Wangara WA and they believe it is the electrical controller unit which requires replacing. Parts are $268 for our particular model.....so really too much I think to invest in an old and becoming more unreliable Waeco. No guarantees it will fully solve the issue and I bet a new problem will appear before too long....no more Waeco's for me....after much research I am inclined to go for the newer Engel steel case Platinum MT45FP for around $1279 with cover and expect better and longer lasting results with the electronics and the Sawafuji swing motor.I will try it on a 240 to 12v inverter though for a little more use hopefully.
Cheers for now Richard
888314
Reply By: GerryG - Sunday, Feb 11, 2018 at 18:34
Hi Richard,
Have you checked the lead, especially the end that plugs into the fridge. I had a similar problem out bush once so we naturally pulled the fridge apart only to discover a couple of hours later that one of the connectors in the female plug on the lead was burnt out.
Just a thought!
616821
Follow Up By: Richard S18 - Sunday, Feb 11, 2018 at 22:43
Hi Gerry,
Yes have checked the 240V leads and no signs of shorting or burn marks.
Thanks for the time and suggestions
CHeers Richard
888264
