Canopy door alarm
Submitted: Friday, Feb 23, 2024 at 18:55
Paul W33
Can anyone help out with a simple plan for canopy door ajar alarm. One too many times have we driven off with the door open.
Reply By: RMD - Friday, Feb 23, 2024 at 19:18
IF your rear vision mirror looks through the canopy front and rear glass, stick an easily visible shape card/ sticker or even a cross of Gaffa tape to the inside of the rear glass. That way you WILL see it everytime it is closed, IF you use your mirrors. There are electrical/ microswitch and light or Led options, which can be wired to indicate OPEN/AJAR with Ignition ON.
645364
Reply By: tonysmc - Friday, Feb 23, 2024 at 21:51
Hi Paul. You can get a gas strut switch which clamps onto your gas struts and is for turning on your lights automatically when you open the canopy door. Instead of a light you could run a wire into the cab and hook up a piezo buzzer! Just make sure when ordering it matches the diameter of your gas struts sliding shaft and outside of the fixed section. Also that you have enough free space on the sliding shaft when the door is closed.
645367
Reply By: IvanTheTerrible - Friday, Feb 23, 2024 at 22:12
We fit switch's to the canopy doors and wire them to the vehicles doors switches so the vehicles door ajar alarm and indicator lamp work when the canopy is open
645368
Follow Up By: Hugh J2 - Saturday, Feb 24, 2024 at 11:59
yep this is the way to go
you can pick up door switch wiring in the column behind the seats.
925640
Reply By: Member - Gordon B5 - Friday, Feb 23, 2024 at 23:28
I’ve got some on my ex Telstra vehicle, I’ll get some pics tomorrow. These work too
well, on some remote corrugated roads I’ve had to tape them up as the vibrations can make them come on. Still rather have them though.
Patrol
645369
Follow Up By: Member - Gordon B5 - Saturday, Feb 24, 2024 at 14:49
Alarm switch
Alarm switch
Alarm switch
925641
Follow Up By: Member - Gordon B5 - Saturday, Feb 24, 2024 at 14:52
This is hooked up to an alarm & a red light on the dash.
925642
Reply By: Member - Bigfish - Saturday, Feb 24, 2024 at 12:51
Having witnessed quite a few doors being ripped off and left a few open myself the only way is with an alarm and a red light easily seen in the front dash. I damaged one on a tree when the noise alarm failed (didnt have the light as backup). I was a remote Telstra tech and plenty of the guys damaged their doors. Telstra installed lights and buzzers and this cut down the damge rate significantly.
645372
Follow Up By: b1b - Monday, Feb 26, 2024 at 14:08
and didn't those buzzers alert you very quickly, but could be a PITA to keep adjusted properly. I was lucky that i didn't lose the wings on my vehicle. But the switch did need constant adjustment after corrugations.
925668
Reply By: 2517. - Saturday, Feb 24, 2024 at 16:17
You could use momentary switchs which you can still buy on eBay,the same as used to be on frig doors and car doors as
well,cheap just hook up to buzzer or light.
645373
Reply By: Allan B (Sunshine Coast) - Saturday, Feb 24, 2024 at 17:32
Undoubtedly, the switch plus audible alarm is the best way to go. You need to search for indicator lights but the audible alerts you even when you are not observant.
A standard switch such as
door switch is possibly the cheapest and easiest way to go. Be sure that the metal body of the switch is
well grounded, possibly by the fixing screw, or by running a wire to ground. The switch connection pin then connects to a piezo buzzer (Jaycar) and other piezo terminal to ignition +12v.
I have such devices on my van, on the vent and the step, and there is no way to ignore the piezo!!!
645375
Reply By: Paul W33 - Saturday, Feb 24, 2024 at 19:35
Thanks all for the advice. I’ll work out a plan.
645376
Reply By: nickb - Saturday, Feb 24, 2024 at 20:34
I did similar as above. Switches on each door hooked up to a loud annoying buzzer in the cab. Saved me a few times...
I got all my bits from Jaycar, you will just need to adapt to whatever lock style you have.
645379
Reply By: Garry L - Saturday, Feb 24, 2024 at 22:37
Paul
What about putting a hook on the inside of the canopy door to hang your car keys on when you are camped up ?
That way when it's time to move on you can't drive off unless you grab the keys from the hook that is attached to the canopy door that is still open - which will remind you to close the canopy door !
Gazz
645380
Follow Up By: Allan B (Sunshine Coast) - Saturday, Feb 24, 2024 at 23:05
Gazz, I also thought of that. But on thinking it through, I figured that it would require a discipline to place the keys. If such discipline could be relied upon then the same degree of discipline could apply to remembering to
check closure……. and as Paul said in the beginning…."One too many times have we driven off with the door open."
925647
Reply By: Member - McLaren3030 - Sunday, Feb 25, 2024 at 06:48
Hi Paul,
The simplest solution is to walk around your vehicle before you get in. Do you tow a van? If you do, do you do a walk around the van before driving off?
As far as hanging the keys from the open canopy tail
gate, that could be an invitation for a dishonest person to avail themselves of the keys while you are distracted, and drive away.
645382
Follow Up By: Garry L - Sunday, Feb 25, 2024 at 08:49
You're on the money Macca
A simple walk around to
check anything left behind, on the ground or open is mandatory as far as I'm concerned. I very rarely use caravan parks and
camp right next to my vehicle so dishonest people doesn't really come into play.
Gazz
Ps - Another simple solution - maybe Paul could just write "
check canopy door " on the steering wheel horn with texta ??
925648
Follow Up By: Batt's - Wednesday, Feb 28, 2024 at 10:11
I can honestly say I haven't driven off with a door open in the 10yrs of owning one maybe paranoid of becoming a statistic after seeing so many people damage there's.
A work college yrs ago ripped his door off costing around a thousand dollars or so on a brand new custom made and painted plate canopy.
925696
Reply By: Member - David & Kerry W - Sunday, Feb 25, 2024 at 10:25
I just hide the keys in the canopy when doors are open. The key is not visable, after wrecking a door twice this method has worked. Just have to remember where you hid the keys! David.
645385
Reply By: Paul W33 - Sunday, Feb 25, 2024 at 14:43
We use the keys in the canopy technique but it’s not failsafe. When we are rushing around loading stuff in the car sorting out my Son things get forgotten. We live out of the car so there is always something going on which creates a distraction.
645388
Reply By: Member - Cuppa - Tuesday, Feb 27, 2024 at 09:00
Had my ex Telstra canopy for 13 years.
Were it not for the often irritating & very loud alarm on the doors I am certain those canopy doors would have been long gone when I sold it recently.
Many a time I considered an inline switch to disable the alarm, but I never did it.
Yes corrugations could make the alarm ‘chirp’ & adjusting the switches was a ‘black art’ involving trial & error, a torch & the video capability of a mobile phone but I never ripped a door off accidentally!
645403
Reply By: Gbc.. - Monday, Mar 04, 2024 at 20:32
A length of yellow and black flagging tape 1/2 way down the door, slightly shorter than 1/2 with a small weight works for me. Hard to miss them hanging down if a door is open.
645429
