Wheel nuts
Submitted: Sunday, Mar 12, 2023 at 14:54
ThreadID: 145414
FollowUps:1
Member - Rude
Can anyone advise if the wheel nuts from a standard steel rim be suitable for a alloy rim to suit the 200 series
Reply By: Member - LeighW - Sunday, Mar 12, 2023 at 15:18
No, you will need alloy wheel lug nuts
643060
Reply By: Bob Y. - Qld - Sunday, Mar 12, 2023 at 16:13
These are what you need, Rude.
Toyota mag wheel nuts
643061
Reply By: Member - Duncan2H - Sunday, Mar 12, 2023 at 19:47
The consequences of getting this wrong are significant.. it would be worth being very certain of the requirements of your rims with regards to the nuts - especially if they are aftermarket rims.
643062
Reply By: Member - Boobook - Monday, Mar 13, 2023 at 06:13
It depends on the alloys you use. For OE the type shown above are correct. For others the steel wheel ones may be correct.
You should consult the manufacturer.
643063
Reply By: Michael ( Moss Vale NSW) - Monday, Mar 13, 2023 at 06:50
Some alloy wheels have countersunk holes and use the nuts Bob has shown above and some alloy wheels have a steel insert pressed into them with a tapered
seat and use the same tapered
seat nuts as steel wheels. So best do your own research so you you get the correct ones.
643065
Reply By: Member - DOZER - Tuesday, Mar 14, 2023 at 12:48
Not thesame, mags run mag nuts, steelies run tapered
seat nuts. If your after mags, check mine which come with nuts.
643075
Follow Up By: ExplorOz - David & Michelle - Wednesday, Mar 22, 2023 at 13:39
Wish your
Classifieds rims where the same as our 200 I need to get a few more or swap them all out.
David
922777
