Towing with a lift kit
Submitted: Monday, Jan 16, 2023 at 15:26
ThreadID: 145247
FollowUps:0
David A37
G'day, I"m after information about a Navara 2010 model with a 2" lift kit towing a 20' semi off road caravan with an ATM 2500, is this suitable? Thanks.
Reply By: Member - McLaren3030 - Tuesday, Jan 17, 2023 at 07:45
Hi David,
I am not sure exactly what you are asking here, but a lift kit should not make any difference to towing as long as the height of the tow ball on your towing vehicle can match the height of the towed vehicle hitch when fully loaded.
642639
Reply By: Gbc.. - Tuesday, Jan 17, 2023 at 08:28
The rear springs might still have the info printed on them about what kg constant load rating they are. "lift" kits come in varying capacities. Chances are you will have to see by doing in your case. Bear in mind as the car drops from the 'attitude' at which it was aligned, the front end alignment disappears so you want a twin cab sitting somewhat 'right' at all times to maintain that relationship.
642640
