Sore seat
Submitted: Thursday, Jan 12, 2023 at 13:20
ThreadID: 145228
FollowUps:3
Member - Alan P3
My good partner is suffering sciatica type pains after a couple of hours sitting in the car. After about 4 hours my behind is getting sore as
Can I please have your suggestions/solutions, e.g. padding that works, or other tips and tricks?
Alan.
Reply By: Member - Duncan2H - Thursday, Jan 12, 2023 at 13:57
Some modern car seats are ridiculously firm.. what kind of car is this.
There's a range of aftermarket cushions shaped perfectly for a car
seat that are worth considering. Amazon/Ebay etc have a good range locally.
642588
Reply By: AlbyNSW - Thursday, Jan 12, 2023 at 15:33
An expensive fix but I fitted Recaro seats to solve the issue with my wifes back. There are some lumber support cushions available which are adjustable you could try
642590
Follow Up By: Member - Alan P3 - Thursday, Jan 12, 2023 at 17:03
Hi Alby,
Thanks for the interest.
Recaro seats were my first thought, but they are a very expensive outlay, especially if they don't solve the problem.
After reading Rob A's advice in the thread, I will explore that first.
We may end up with both!
Alan P.
922175
Follow Up By: Bob Y. - Qld - Saturday, Jan 14, 2023 at 14:12
Was going to recommend Kalchris’s suggestion Re the Airhawk, but had to Google them to make sure I had the name correct! Very popular with some truck drivers, especially linehaul folk, doing big kms every day.
We had a Landcruiser wagon, that had adequate seating, but not really comfortable over a 10 hour day. We had a firm in
Bowen Hills(
Brisbane suburb), called Motorcraft, that fitted pneaumatic lumber supports to the factory seats. Certainly made a huge difference to our travelling comfort.
922190
Reply By: Rob A1 (SA) - Thursday, Jan 12, 2023 at 15:57
My first suggestion is to have your conditions correctly diagnosed. Jumping to the incorrect solution will only create more problems. You need to understand the causal relationships before getting a solution(s) that works for each of you separately.
A personal example would be when I experienced severe back pain suddenly and only after around 30" of driving. My wife already has a badly damaged lower spine. Car at the time had excellent seating.
A trip to my physio found two problems, one with my lower spine and another where the sciatic nerve joins with the hamstring. Both need on going treatment but from the seating perspective two separate fixes as
well. First was to go to a specialist chair seating
shop and get some memory foam cut in a specific way as required by my physio. Second solution was to make physical adjustments to the base of the
seat to bring it past completely level, almost all cars
seat base cants backwards, and then using the wedge to take the pressure of my lower back. That helped greatly and succeeded thanks to specialist advice on what the problem was and how it could be remedied while driving.
We changed over cars a couple of years ago and purchased one with full electric
seat adjustments which has been so good we no longer need the memory foam wedges. This years trip was 14,500km through the NT, Gulf Country,
Cape York and back to
Adelaide towing our AOR Matrix over some pretty ordinary roads. Neither of us had a problem on any day of travel, always feeling relaxed and pain free.
Rob
642591
Follow Up By: Member - Alan P3 - Thursday, Jan 12, 2023 at 17:06
Hello Rob,
Thanks so much for going to the trouble of recounting your experiences.
We will go along these lines first and see how we go.
Regards,
Alan P.
922176
Reply By: Member - Kalchris - Friday, Jan 13, 2023 at 18:08
Alan my wife and I both use an inflatable cushion from AirHawk -
https://airhawk.com.au. These come with a simple to use pump allowing your desired inflation pressure and comfort to be achieved. A happy customer couple with no affiliation with the company.
May be a far cheaper solution than Recaro seats.
Hope this may help.
Chris
642600
Reply By: Member - Kia1 - Saturday, Jan 14, 2023 at 11:24
My wife had a problen sitting for any length of time. We purchased a GEL cushion from autobarn, they have two shapes and the one we chose works very
well, Problem solved.
Cheers.
642610
Reply By: Member - Rob S (NSW) - Thursday, Jan 19, 2023 at 15:12
You could try one these memory foam cushions $19 Kmart
bought one for the 80 series for the 9000klm return trip to Cape
York last year, dose make you sit higher and harder to get in if you have a high vehicle,
did make things more comfey.
k mart memory foam cushion
642679
