Winch or not....
Submitted: Tuesday, May 10, 2022 at 23:15
ThreadID: 143687
FollowUps:7
Member - Heiner B (INT)
G'day mates,
after al my researches and your help I was ready to buy a winch and install it.
With my friends here I got a huge discusion about the need of it...
They say :
if you ever get in the situation to need a winch you were on the wrong way.
if you are stuck then you certainly don't want to move forward but rather backward .
More important is a good recovery kit...
Dont wast your money..
What do you think?
Heiner (finally back in australia)
Reply By: Member - Core420 - Wednesday, May 11, 2022 at 06:19
Definitely agree. I don't carry a winch, mainly because I mostly travel outback and in deserts. There are not many anchor points. If I were to go into the high country then I'd consider one.
640485
Reply By: qldcamper - Wednesday, May 11, 2022 at 07:38
If you have already run the question by the group and got their opinions, why are you asking it again?
640486
Follow Up By: Member - nickb boab - Wednesday, May 11, 2022 at 08:27
Good question hmm . What was the other post with the huge discussion ?? I do remember reading it, but can't find it now..
Nor do I think this latest post makes a lot of sense considering
919565
Reply By: Genny - Wednesday, May 11, 2022 at 07:50
I was certainly grateful some kind soul had a winch on Fraser. MaxTrax, and an hour on the shovels, and we were still going nowhere. Mind you, there was nearly two tonnes of camper trailer on the back.
640488
Follow Up By: Gbc.. - Wednesday, May 11, 2022 at 14:16
That’s the reality of having a winch. You spend half your time recovering ill equiped stuck people. I wouldn’t be without mine though, I travel solo. As for only going forward, I think the OP should canvass people with actual experience.
919572
Reply By: Jackolux - Wednesday, May 11, 2022 at 08:47
Why ask what others think , you know where you go .
( if you are stuck then you certainly don't want to move forward but rather backward ) no that's garbage I have winched myself out of trouble by going forward plenty of times .
I have probably help others more than myself .
I have always had a front mounted winch , it doesn't get used very much but when it's needed Im glad it there
( More important is a good recovery kit ) you should have a kit anyway winch or no winch
Yep they cost a few $$$$ and its extra weight .
640489
Reply By: Member - McLaren3030 - Wednesday, May 11, 2022 at 09:10
Hi Hiener,
These friends you were discussing with, do any of them have a winch? My guess is that they don’t.
I have used my my winch to get me out of trouble in sand by using another vehicle as an anchor, and winching forward off them on more than one occasion, and with a 1.5 Tonne camper trailer on the back. Just because as one person has put it “you are mainly in the desert so not many anchor points”, another vehicle makes a great anchor point.
Don’t second guess yourself once you have made a decision based on all the facts and figures, pros and cons. Yes a good basic recovery kit is also a must, and should include things like gloves, Maxtrax/Tredd Boards, rated shackles, snatch strap, winch extension strap/rope, snatch block, tyre plug repair kit, spare tyre valves and valve inserts, an air compressor, tyre deflater, a quality tyre pressure gauge. A winch also forms part of the recovery kit.
640491
Reply By: nick g1 - Wednesday, May 11, 2022 at 18:02
Sometimes nature throws something at you that you carn't predict. We where at a remote
camp in a N P and had a wind wild storm overnight. Went to check rd out and a tree had come down over the rd. Yes we could have spent hrs chainsawing it but one winch pull got it out of the way much quicker.
I would say if you can afford it go for it.
It is another tool in you recovery kit. You won't need it until you need it. It can be used for a lot of other things other than recovery, like draging trees for firewood.
640500
Reply By: Michael H9 - Wednesday, May 11, 2022 at 21:08
I've got a Bogout wheel winch for when I'm stuck and nobody is around. It weighs the same as a snatch strap. I've been all over the place, deserts, beaches, high country, all solo. I couldn't be bothered carting either a bullbar or a winch everywhere, they add weight and add fuel expense. After 30 years I see no reason to change. Many people disagree with me though.
640503
Follow Up By: Michael H9 - Thursday, May 12, 2022 at 08:17
Here's a handy tip about
winches from someone who can't be bothered buying one. :-) On regular occasions I've pulled people with
winches out of bogs with a tow rope because their
winches don't work anymore. Maybe they've been through too many river crossings and not been serviced enough, who knows? But it's a bummer to cart around your expensive insurance policy for years and have it fail right when you need it most. Test and service them regularly just like your car.
919586
Reply By: Member - Heiner B (INT) - Wednesday, May 11, 2022 at 23:47
Thank you for your constructive responses.
I decided to buy the winch thanks to my gut feeling and your answers.
In my ARB Bullbar the mounts fits most
winches.
Since I will be alone on the road I find it important to secure me as far as possible / necessary.
The purchase is made and the installation follows. (DIY!!!???).
For all those who consider the contribution superfluous: Sorry to have robbed your time.
Heiner
Translated with www.DeepL.com/Translator (free version)
640506
Follow Up By: qldcamper - Thursday, May 12, 2022 at 04:18
If your alone, I would be investing in a sat phone and something that displays your exact position,or an epirb.
If you experience a snake bite then at least they will find your body.
919582
Follow Up By: Gbc.. - Thursday, May 12, 2022 at 07:15
DIY winch install is simple enough, but can be heavy work trying to locate it in behind the bar. Some cars need the bar removed.
Good old ARB keep insisting that
winches be mounted 'feet forward', thus necessitating a quick rotate of the winch gearbox 90 degrees - this is about the easiest part of the process. Then you have to hold the winch up in place while locating the mounting bolts.
Installing
winches is always best done with a friend.
919585
Follow Up By: Member - Heiner B (INT) - Thursday, May 12, 2022 at 12:34
@qldcamper: I am thinking about a sat phone with prepaid.
an epirb (personal
beacon) is already on board (i think this should be mandatory for all travelers).
@Gbc..: That's exactly what I'm worried about. the weight of the bullbar AND the weight of the winch.
So I definitely dont do it alone.
thanks.
Heiner
919593
Follow Up By: Member - Warren H - Thursday, May 12, 2022 at 15:13
Heiner,
Take a look at the communications section on this site or
here for info on satphone networks available in Australia. Thuraya is definitely the cheapest option for purchase and plans, calls are a standard Australian mobile number for incoming. In south east Australia the satellite is fairly low in the sky ~22 deg so hills and thick belts of trees can limit reception more than in the north. I'd also use headphones or an earpiece to maintain a good lock on the satellite.
919598
Reply By: Member - Michael P (QLD) - Thursday, May 12, 2022 at 13:42
I have carried a winch around for many years on the front of My vehicle and only ever helped one or two others and often thought why bother, particularly at change overtime. Last year alone in the backblocks of
Currawinya NP managed to get horribly bogged. Now I know that the effort of maintaining and carrying it around was worthwhile.
Regards,
Mike P.
640513
Reply By: Member - David H72 - Sunday, May 15, 2022 at 16:17
If you do a DIY install make sure you run all your cabling to the rear and side, not across the front, of the engine bay then, if you have a crash, you don’t have all that 12v cabling fractured or chafed, trying to cause a fire.
640545
