Deleting old map
I have EO Topo 2019 & 2021 on my computer. Is is possible to delete 2019 without deleting 2021?
Reply By: TrevorDavid - Tuesday, Sep 28, 2021 at 17:48
Michael
To be honest I don’t actually remember, but if you go into data manager you can only delete one map set at a time, the first will be black rather than grey.
TrevorDavid
dontyajustluvit
AnswerID: 638117
Follow Up By: Member - Michael H54 - Wednesday, Sep 29, 2021 at 07:54
When i look in Data Mgr it shows green ticks against EOTopo 2019 & 2021. LoRes, HiRes, & XHiRes packs all have Version 2021 next to them & the delete buttons do not show an option to delete 2019.
Likewise in settings under the App Resets header, there is are option to clear the main DataBase but no option to select 2019 map.
Thanks for replying. If no one else knows how to do it I will delete both maps & reinstall later today.
FollowupID: 916404
Follow Up By: TrevorDavid - Wednesday, Sep 29, 2021 at 08:27
Mike
That’s interesting, can’t remember it being difficult though, perhaps I dumped the lot and started again???
Clearing the main data base will only clear places, treks , comments etc.
Clearing the maps data base will clear the offline maps.
If no one can help shortly maybe drop Michelle a line at the help desk.
Good luck
TrevorDavid
dontyajustluvit
FollowupID: 916408
Follow Up By: Member - Dick L - Wednesday, Sep 29, 2021 at 08:37
When I installed ExplorOz I didn't bother installing the 2019 maps as the 2021 are updated versions of them.
So I can't see any reason why uninstalling 2019 maps would cause any problems.
FollowupID: 916409
Follow Up By: TrevorDavid - Wednesday, Sep 29, 2021 at 08:43
Yes Dick,
Certainly won’t cause any problems. I had both for a while then dumped the 2019 maps. IMHO they just aren’t required with the 2021 maps being so much better.
TrevorDavid
dontyajustluvit
FollowupID: 916410
Follow Up By: Member - wicket - Wednesday, Sep 29, 2021 at 12:52
Michael H54
You will need to look a bit closer at data manager, you will see a little eye to the right of the single line reference to the 2019 maps , tap it and all will become clear.
FollowupID: 916421
Follow Up By: Member - Michael H54 - Wednesday, Sep 29, 2021 at 14:17
Thank you Wicket. Michelle helped me out earlier. That was the problem. I didn't even notice the 2019 "eye" All sorted now.
FollowupID: 916425
Reply By: Frank P (NSW) - Wednesday, Sep 29, 2021 at 10:02
Michael,
"Is is possible to delete 2019 without deleting 2021?"
Yes it is. I just checked on an old device that has both 2019 and 2021 maps installed.
Go to Data Manager. The 2019 and 2021 map packs are listed separately. Use the black buttons to delete the maps you don't need. Once you've deleted the East, West and Central packs the grey buttons for the 577k and Base packs will turn black and you'll be able to deleted those as well.
AnswerID: 638130
Follow Up By: kgarn - Wednesday, Sep 29, 2021 at 12:59
In Data Manager the 2019 maps are listed below the 2021 files.
You may need to tap on the "eye" icon to make them visible.
Refer image below
Ken
FollowupID: 916422
Popular Products (13)
