Show distances in Traveller app.
Hello. How can I get Traveller to display distances between towns etc. I’m using EO Topo 2021 maps.
Thanks.
Reply By: Frank P (NSW) - Sunday, Aug 29, 2021 at 19:28
Siringo,
Create a Trek between the two towns. It's easy. Tap one town, select goto. The town will appear in the navigation panel. Tap the second town. Select goto. Tap Add. If route options are offered select one of them. The second town will appear in the navigation panel, which will also show the distance between the two via the route chosen.
If you keep doing that for successive towns or waypoints, against each one you will see a distance from the last place plus a cumulative total.
AnswerID: 637712
Reply By: Member - Jim S1 - Monday, Aug 30, 2021 at 16:47
Am trying to do this on my iPhone, and tapping on a place on the map doesn't get any reaction.
Help !!
Jim
"Sometimes I sits and thinks, and sometimes I just sits." A fisherman.
"No road is long with good company." Traditional
AnswerID: 637717
Follow Up By: Member - Warren H - Monday, Aug 30, 2021 at 17:15
It has to be a 'Place' either an ExplorOz place or one you have created.
NT Pajero
2007 Goldstream Crown
FollowupID: 915834
Follow Up By: TrevorDavid - Monday, Aug 30, 2021 at 17:16
Jim
Drop a pin (waypoint) at each location and try again
TrevorDavid
dontyajustluvit
FollowupID: 915835
Follow Up By: Frank P (NSW) - Monday, Aug 30, 2021 at 18:52
Jim S1,
Position (scroll) your map to position the cross-hairs at the approx location of the place you're interested in. Eg if you're zoomed out a town could be a black dot on the map with a green cluster adjacent.
Use one of the zoom methods to zoom in, or if there is a cluster of Places tap that to expand and keep tapping/zooming until you get the Place you're interested in.
If it's not there, scroll to accurately place the cross-hairs where you want them to be then create a way pointand goto that.
FollowupID: 915836
Follow Up By: Member - Jim S1 - Monday, Aug 30, 2021 at 19:11
Thanks for all the help. I’ve been away from the puter so apologies for not acknowledging your help.
Will give it a go now.
Jim
FollowupID: 915837
Follow Up By: Member - Jim S1 - Monday, Aug 30, 2021 at 19:33
Ah. ……. success!!
Now to practice doing it a few times.
Thanks again for all the help.
Jim
FollowupID: 915838
