chemicals
Submitted: Thursday, Jul 22, 2021 at 19:19
Member - Barry P (VIC)
what chemicals are you using in porta pottys these days?is there any products available at super markets?thanks in advance
Reply By: Member - Scrubby (VIC) - Thursday, Jul 22, 2021 at 19:38
" NapiSan " works good.
Scrubby.
637267
Reply By: Member - Bigfish - Thursday, Jul 22, 2021 at 20:05
I,ll second nappi san. Great stuff.
637269
Reply By: Gone Bush (WA) - Thursday, Jul 22, 2021 at 20:21
I use this from Coles. You can get a similar
home brand in Woolies.
Laundry Soaker
The important thing is a higher than 30% sodium percarbonate. Put a capful in some water and chuck it into the
toilet canister. Replenish or empty every 3 days.
637270
Follow Up By: tim_c - Monday, Aug 02, 2021 at 15:40
I don't even bother with the water - just means I'll have to empty it again quicker. By the time it's needed, there's enough water in the tank/cassette to dissolve the powder, just from normal use.
915412
Reply By: Bazooka - Thursday, Jul 22, 2021 at 20:29
Reply By: Sand Man (SA) - Friday, Jul 23, 2021 at 08:00
Either brand of the mentioned Laundry soakers are ok.
As a matter of interest, the Coles Ultra Oxy Action has dropped slightly in the % of Sodium Percarbonate as it used to.
It is now rated at 320g/kg, or 32%.
Napisan Vanish Gold Oxi Advance is rated at 330g/kg, or 33% but the difference is negligible and the Coles brand is probably cheaper.
What I like about Napisan is that it comes with a natty little scoop in the container which makes distribution of its contents into the porta potti that little bit easier.
If you like this one, just look for the pink container with the gold lid.
637273
Reply By: Peter_n_Margaret - Friday, Jul 23, 2021 at 08:37
Alternatively, you can buy 100% sodium percarbonate from brewers supplies or on line.
637274
Follow Up By: Michael ( Moss Vale NSW) - Friday, Jul 23, 2021 at 19:06
That's what we did, a few kilos for $30 roughly , enough for a lifetime. Regards, Michael
| Patrol 4.2TDi 2003
Somewhere you want to explore ? There is no time like the present.Member My Profile My Blog Send Message |
915289
Reply By: Phil G - Saturday, Jul 24, 2021 at 07:28
This is what we've used.
Aldi DiSan (very cheap) is the same as Napisan - does the job but doesn't control odour quite as
well as the others so we found needed changing every few days. We also use it to clean our
grey water tank - pop a heap in at the last day of a trip and let it swish around on the way
home.
Thetford Blue is the most effective and the sachets are easy to use (15 sachets about $25). Thetford green not as good.
Portasol works pretty
well and can be bought from Bunnings and only needs 40mls each time so you get 25 doses out of a litre for $20.
637280
Follow Up By: Nomadic Navara - Sunday, Jul 25, 2021 at 11:57
I would not be carrying
Thetford Blue- Not suitable for septic system or composting
toilets.
915302
Follow Up By: Phil G - Monday, Jul 26, 2021 at 07:12
Yeah, I only use Thetford Blue and Portasol when we are able to dump in town sewerage. They work the best.
We use DiSan when more remote but find we end up emptying the cassette more often.
915308
Reply By: Kazza055 - Saturday, Jul 24, 2021 at 12:52
It is the sodium percarbonate in these laundry soakers that act on the solids and break it down and neutralise the smell so the best thing to do is use it the same as you do at
home.
For urine only, sodium percarbonate has absolutely no effect.
637283
Follow Up By: MickeyJ - Saturday, Jul 24, 2021 at 13:55
We just add vinegar and that seems to stop the smell from just urine (Our most common usage pattern)
915291
