Thursday, Jun 10, 2021 at 11:59
The main difference with The Alpine Way (and a few other roads around here) is that the steep hills are longer than normal hilly country. If your cooling system is marginal, you can get away in most cases because mostly the steeper hills are relatively short and by the time the engine starts to heat up or evens tarts to overheat, the
hill is over, and it all cools down again. In the Snowy Mtns, the hills are a lot longer (Yeh - I know, quoting Banjo Patterson, The
hill are twice as steep and twice as rough). One saving grace is that normally the temperatures in this area are cooler, but you cannot rely on this all the time.
Gary: These roads are used by trucks (not normally semi trailers, but B doubles do use the Snowy Mtns Highway), so as long as you drive sensibly -you should have no troubles.
* use the engine to control the speeds downhill - save your brakes for an emergency
* keep
well to the left on the corners,
* drive at a sensible speed,
* monitor your mirrors and when safe, move over to allow traffic behind you to pass and
* your tow vehicle is adequately sized, powered and the van is loaded correctly
you should have no troubles at all. This area has to be, apart from the Victorian high country and Tasmania, the best to tour in. Come September, there will still be snow on the peaks, the grass down low will be green and high, the roads should be cleared of fallen trees etc. It is a superb time to visit. To quote Nike - Just Do It... Take your time, absorb the spectacular scenery and you will want to come back for sure.
914695
