fuel lines exposed in wheel wells
Submitted: Wednesday, May 18, 2022 at 18:21
ThreadID: 143730
FollowUps:3
Alex S11
Hi there!
I have LRA aux fuel tank installed in my prep to do crossing of simpson. I was surprised to see the filler pipe and some rubber fuel lines exposed in the wheel well of the ute's tub. I was told that the install was done correctly and in accordance with LRA instructions, but I wonder if this is a problem as stones can damage these lines.
Can anyone comment?
Thank you!
Alex
Reply By: Member - LeighW - Wednesday, May 18, 2022 at 19:20
Depends where they are situated with regards the tread, ie on my Prado the edge of the mud gaurds cops a beating from stones as does anything behind the wheel. Areas inner from the wheel and to the front seem to be spared which makes sense as most of the stones exit via the rear of the wheel.
640588
Reply By: Member - Core420 - Wednesday, May 18, 2022 at 21:01
If you're concerned you can protect them with pool noodles or corrugated split tubing.
640589
Reply By: Alex S11 - Wednesday, May 18, 2022 at 21:15
Thank you for your replies. Both are helpful.
640590
Reply By: Member - John - Thursday, May 19, 2022 at 06:30
Good morning, pics of the location of the fuel line etc would help, cheers.
640593
Reply By: Member - nickb boab - Thursday, May 19, 2022 at 07:45
It does sound like you may want to make up a metal guard as it will get peened by Stones if it is like you are suggesting exposed to the wheel but most utes have guards as standard depending on what sort of ute well or tray body I guess ..
Maybe more info or photo . Both roads leading to The Simpsons ...
Birdsville and
Oodnadatta are extremely Stoney .
640595
Reply By: Alex S11 - Thursday, May 19, 2022 at 09:23
wheel well
rubber guard
looking up from inside of the front of the wheel well
some pictures of the installation with my mark up.
640598
Follow Up By: Member - nickb boab - Thursday, May 19, 2022 at 09:31
Thanks for the photo update I would definitely be trying to cover this as this is going to be very exposed definitely trouble in the making.. I would be looking at some of that hard black plastic sheeting apox 3/4 mm thick zipp tied on etc
919674
Follow Up By: Member - LeighW - Thursday, May 19, 2022 at 10:18
Personnaly I would cover it protect it if sufficient room to allowfor mud build up on tires etc.
Practically I have an old KIA sportage which has steel fuel lines etc in a similar position, 25 years old and no damage to those lines.
919675
Follow Up By: Member - John - Thursday, May 19, 2022 at 17:36
To me, not acceptable, looks like raw exhaust tubing has been used as the filler tube. The whole tube, connectors etc should have been covered with some sort of protection. Good luck
919677
Reply By: qldcamper - Tuesday, May 24, 2022 at 05:27
Unprofessional.
Fuel lines should not be in a wheel arch.
Contact the installer and complain.
640646
Reply By: alfoequipment - Tuesday, Jun 07, 2022 at 13:20
This post has been read by the moderation team and has been moderated due to a breach of The Advertising/Self-Promotion Rule
Forum Moderation Team
640775
