Ipad for navigation
Submitted: Thursday, Mar 04, 2021 at 11:05
Steve A13
My first post so be gentle. Before i sign up for the Exploroz apps i would like some advice on what Ipad to look for that will be suitable for this application. I understand I need wifi and cellular to use the GPS function and I know what to look for in a ipad to get this, but however dont really want to spend $700 on a new Ipad . Some secondhand units say "3G" but I thought this was being phased out soon , so would that render the unit as useless for navigation? I am I better to find a 4G unit ? What Gb do I need ? or what would people recommend.
Many thanks for any assistance on this
Kind regards
Steve
Reply By: Member - Jim S1 - Thursday, Mar 04, 2021 at 11:52
Hi Steve
Have had iPads forever and never had a problem. Definitely 4G, and probably 128Gb. You could work OK with 64 Gb.
If you can't buy new, next best is Apple's second hand "refurbished" ( Apple Australia) , then you take pot luck. Make sure you can contact seller by Australian phone number (try it), and use PayPal ( they hold your money until you are happy).
Good luck.
Jim
| "Sometimes I sits and thinks, and sometimes I just sits." A fisherman.
"No road is long with good company." TraditionalLifetime Member My Profile My Position Send Message |
635374
Reply By: Member - Mark (Tamworth NSW) - Thursday, Mar 04, 2021 at 12:53
See Duncan2H's thread (141184) a couple down below yours, $250 is all you should need to pay for a good Android tablet.
Sounds like you don't use a Tablet heavily, perhaps you can get away with hot spotting to your phone so you don't need one which uses a SIM card, which are much cheaper.
My sub $250 Samsung TabletA with 64GB runs ExplorOz Topo and maps perfectly
Mark
635375
Reply By: Michael H9 - Thursday, Mar 04, 2021 at 13:22
You need the 3g/4g model ipad because the gps chip is incorporated in the sim control chip. Not so with an Android tablet, the gps chip is separate. The ipad gps will work without a sim card in the slot but obtains and maintains a fix quicker with a sim card because the gps chip has the ability to use mobile phone tower data to trangulate its position quicker than just obtaining a satellite fix.
Whether it can still obtain the mobile phone tower data after 3G is turned off, I don't know, but at worst it will function the same as no sim in the slot at all.
If you aren't tied to Apple at all then Android is a good and cheaper option.
635376
Reply By: RMD - Thursday, Mar 04, 2021 at 14:37
Steve
Apple do what Apple do and it costs more for same functionality. Do you really require a tablet device to read phone towers and will just a GPS chip in the device do your navigating with your chosen program be ok for you?
I am not a big user of navigation, others a lot more, but have never had a device which relies or uses towers and phone to find out where I am lost. If you want to spend the additional $450 for a bite of an Apple then ok, It seems some of the recommendations in this thread/post and previous ones below would suffice.
635377
Reply By: Dusta - Thursday, Mar 04, 2021 at 15:02
no need for data connectivity. purchase the map pack along with exploroz and run the maps offline. if you need internet hotspot your phone .
Lenovo do a 10.3" tab for under $250 and will do everything the expensive overpriced samsung and crapple devices do for 4 times the price.
635378
Reply By: Member - David W14 - Thursday, Mar 04, 2021 at 18:30
I have an none cellular I-Pad air which l hotspot to my I-phone when there is reception, when there is no reception l use the offline Eo-Toppo offline maps and a stand alone GPS ( Bad Elf Pro) Works
635382
Reply By: Stephen L (Clare) SA - Thursday, Mar 04, 2021 at 20:07
Steve
If you are not going to use the SIM Card facility to go online, why not buy a good Bluetooth GPS mouse for far less the difference between WiFi and WiFi plus cellular.
635385
Follow Up By: LindaHaynes - Friday, Mar 05, 2021 at 18:11
You're right Stephen (Y)
912977
Reply By: Steve A13 - Monday, Mar 08, 2021 at 11:23
Thanks to everyone for your replies I will give some thought to what has been said do a bit more research and maybe come back with a question or two
635454
