Differing tyre size for spare
Submitted: Friday, Jan 08, 2021 at 17:25
Member - Michael H54
I plan on doing some desert driving. I have 5 x 265 70 R17 tyres. Can I also utilise one of my original tyres 265 60 R18 as a second spare in case of emergency. Will the slight size difference wreck the auto box or the diff lock? Can I still use low range?
EO Tyre Comparison
Reply By: Steve in Kakadu - Friday, Jan 08, 2021 at 17:44
None of the size differences are slight.
Absolutely
Absolutely not.
Just buy another 17" rim and put the 265 70 17 on it, it will be a hell of a lot cheaper.
634687
Follow Up By: Member - Boobook - Saturday, Jan 09, 2021 at 07:04
True. Another alternative is just to buy a tyre, and learn how to change it. Second-hand tyres in that size are a dime a dozen.
912049
Follow Up By: Michael H9 - Saturday, Jan 09, 2021 at 07:47
Yeah, a decent second hand 265/70/17 can be had for around $50 and is a lot lighter to carry without a rim. You can get it put on a rim at any of the little towns if it's needed and saves waiting for a replacement to get delivered. Get a plug tyre repair kit for most on the road emergency fixes. Make sure the tool is metal not plastic or it can snap off and you'll spear your hand. It's not pretty, I've seen it happen. The ARB kit is very good.
912051
Follow Up By: Member - Michael H54 - Saturday, Jan 09, 2021 at 09:30
Thanks Michael H9. I have a good
puncture repair kit but will it work on a punctured sidewall? I'm driving Mt Dare to
Birdsville on the French Line & Rigg Rd and I can't see any small towns on my map. Are there
places out there not on the map?
912057
Follow Up By: splits - Saturday, Jan 09, 2021 at 13:46
It depends on the size of the hole in the sidewall. It is not uncommon for them to be 20, 30, 50 mm long or even larger. If your repair kit consists of externally applied plugs only then they won't be able to do it.
If you are not familiar with all the equipment to repair tread, shoulder and sidewall damage then have a look through the Rema Tip Top and Beadell Tours website
912061
Follow Up By: Michael H9 - Saturday, Jan 09, 2021 at 18:46
I've seen 4 to 5 plugs put into a sidewall as an emergency repair. It's certainly not road legal of course but you can drive on it if you have to. You'd be very unlucky to get a sidewall stake on the main Simpson tracks, they mainly occur on overgrown or disused tracks or cross country travel. You can see them put quite a few into a Land Rover Discovery sidewall on Ron Moon's
Great Australian Bight Youtube video but that was a really tough pretty virgin track.
912069
Follow Up By: AlbyNSW - Saturday, Jan 09, 2021 at 19:41
As mentioned you need to stick with the same rolling diameter but I would seriously consider if you need to carry a second spare?
There is nothing between Mt Dare and
Birdsville but on a trip like that I find one spare and a decent repair kit is ample.
Travel with what you feel comfortable with but I haven’t carried a second spare in over 10 years. For me the benefits of the weight savings outweighs the chance I would need it.
912070
Follow Up By: Gramps - Saturday, Jan 09, 2021 at 20:36
I'd carry a second spare and be done with it. The extra 30 - 40 kg is neither here nor there in the overall scheme of things.
912071
Follow Up By: Michael H9 - Saturday, Jan 09, 2021 at 21:38
It's here, around my waist....and my wife said I shouldn't be carrying it. :-)
912073
Follow Up By: Bob Y. - Qld - Saturday, Jan 09, 2021 at 22:41
This happened at Kidson
Bluff, on CSR, in Aug, 2019. Continued to drive on it till about
Halls Creek, adding a string or two, every day or so.
Roadside Repairs on the Canning.
When travelling from Mt Dare towards Dalhousie, resist the temptation to travel on the short cut, and go through Bloods Ck. Less risk of tyre damage that way.
912074
Follow Up By: Member - Michael H54 - Sunday, Jan 10, 2021 at 09:48
Thank you all for your replies. What prompted my question was the fact there is a 27mm diameter difference. I was thinking that equates to 13.5mm each side. Which is about the difference in tread thickness between a new tyre and a worn one. But I won't be doing that now. I will heed all the advice on this excellent
forum.
912086
Follow Up By: Blown4by - Sunday, Jan 10, 2021 at 14:13
If you use the second spare for emergencies only, and as you say in desert country, the the difference in tyre rolling radius won't cause you any mechanical problems. The tyres can 'slip' in the dirt and your diff will be working a bit harder, but no harder than when going around a corner when the inside wheel has to travel less distance than the outside wheel. I wouldn't mix those tyres on bitumen though or if you are doing lots of
rock work where the tyres cannot 'slip' easily and if you get 'axle wind up' additional load will be placed upon the drive line. As others have said, a 265/70R17 tyre & rim can be purchased inexpensively say from tyre shops where ppl with too much money have traded in their tyres and rims for a larger size or a flasher set of mags, etc. In addition to carrying a tyre temporary plug kit, for emergencies, also consider carrying a few spare tubes, vulcanising or cold patches, some tyre sleeve repair material and an el cheapo lever operated bead breaker and rubber mallet. Also learn how to use them and how to mount and demount a tyre on a rim.
912092
Reply By: Member - Cuppa - Sunday, Jan 10, 2021 at 16:37
I guess we are all different. One of the things which gives me confidence & helps me to enjoy driving in remote areas is knowing I have done all I can to ensure our vehicle will be reliable, & that stuff we rely on is in serviceable condition. If we were in trouble & someone offered me an unknown second hand tyre to get out of trouble I’d jump at the offer, but I certainly wouldn’t be buying a second hand tyre to carry with us when I could get a new one. In your situation I would buy a matching tyre & rim as a second spare. We all know 4wd’ing is not a cheap pastime, but sometimes we get away with going cheap when 4wd’ing near
home. It’s not the same in remote areas. If it were me & I had a
puncture out there, I would still enjoy the experience knowing I still had one good spare, but without that one good spare the worry factor would take away a lot of the enjoyment. So think of the cost of a second good spare as the cost of ‘happiness’. That way, even if you never need to use it you will have had good value from it. ??
634721
Follow Up By: Member - Michael H54 - Sunday, Jan 10, 2021 at 17:15
Yes a couple of hundred bucks isn't much in the scheme of things.
912093
Follow Up By: The Explorer - Sunday, Jan 10, 2021 at 20:47
Economics comes into play as
well. I was wondering around the Wheatbelt in WA the other day without two spares - Hardly "remote" so why bother. Got a flat (unfixable)...mmm, wasnt going
home for another week or so and figured I couldnt drive around with no spare.
Of course closest town didnt have same brand/type and no second hand ones of a similar size. Solution...brand new tyre, same size another brand (mickey thompson). Cost $540. Yippee. Lesson learnt.
Moral of story, carry two spares when away from larger cities even if not "remote".
912096
Follow Up By: David M - Monday, Jan 11, 2021 at 08:29
You don't need a second spare until you really need one.
Dave.
912098
Follow Up By: Member - Cuppa - Monday, Jan 11, 2021 at 08:45
Bob Y wrote “ When travelling from Mt Dare towards Dalhousie, resist the temptation to travel on the short cut, and go through Bloods Ck. Less risk of tyre damage that way.”
And takes around the same time. We pulled our Tvan through the rocky ‘short cut’ (& quite enjoyed it actually) but the advice from Bob is good. We didn’t damage any tyres, but the risk of doing so was high. Very rocky often difficult to see where the track was, & with some pretty good washouts to get around too. We went Dalhousie to Mt Dare, left at the same time as others who took the Bloods Ck route & we both arrived at Mt Dare within minutes of each other.
912099
Follow Up By: maurice b - Monday, Jan 11, 2021 at 18:46
You can see the difference in size in this image. I would not mix these two sizes to avoid diff damage.
size comparision
912105
Follow Up By: OzzieCruiser - Monday, Jan 11, 2021 at 19:38
The OP already put up the difference in his original post - correctly in mm so why put this up - particularly in inches when the OP has already agreed that the difference is too great and is not going to proceed with his proposal.
912106
Follow Up By: maurice b - Monday, Jan 11, 2021 at 19:54
@Ozziecruiser The other post does not show a side by side comparison . Many people refer to tyres and rims in imperial size especially the heights. When have you see are 16x8 rim referred to as 40.6cm x 20.3cm. So your post was totally unnecessary. I was only trying to help....the end
912107
Follow Up By: OzzieCruiser - Monday, Jan 11, 2021 at 23:08
Well as the OP has already decided what to do - as I said your post is not needed - and the tyre sizes (not wheel size) he was talking about are metric so metrics should be used.
912110
Reply By: Member - DOZER - Wednesday, Jan 13, 2021 at 12:18
Its 550 kms across the french line. My first question is how new are your current tyres? You should be looking to have the toughest version, not a mud terrain, i used cooper st. i took a 6th spare strapped down where the second row seats came out, and placed things inside rim and on top. aswell as all around, keeping weight central and low. I never needed it or the spare, but as you say, its a long way between drinks out there. Personally, if you have good tyres and this spare, use it....in sand you wont have any issues. If you want to run the difflock, place the spare spare on the front. Just make sure it fits and you have the right nuts/spanners to change it too.
634751
Follow Up By: Member - Michael H54 - Wednesday, Jan 13, 2021 at 15:56
Yeh all good Dozer. I have 2 sets of 5 tyres. A set of 18" and a set of 17". The 17" which are almost new & 10 ply, get put on when I'm going on corrugations. So I was asking if when I put the 17" on could I use one of the 18" as a second spare. Thanks for your input.
912128
Reply By: Alan H11 - Thursday, Jan 14, 2021 at 07:02
We had one spare for 49,000 Km in South America - needed it but not a second spare; carried two spares in 45,000 Km in Africa - no punctures, could have done the trip with no spares at all; we started our 45,000 Km in Australia with one spare, later in the trip we added a second spare (WA government advice for GRR) - we had one
puncture and could have done the trip with only one spare (this included GRR and Mt Dare to
Birdsville). Outside the "big trips" we haven't had a
puncture in at least a couple of decades.
I'd go with 5 wheels and tyres of the same size, a good repair kit, a compressor, and no more.
634770
Follow Up By: Michael H9 - Thursday, Jan 14, 2021 at 07:16
I think the problem is mental. When you're remote and you kill a tyre, then you're remote without a spare anymore so the mind games begin. I had 3 flats in a day on the
Oodnadatta Track once, and I didn't have an extra spare, but I got by with a repair kit and local repair shops.
912136
Follow Up By: Alan H11 - Thursday, Jan 14, 2021 at 07:25
I take your point - we had a
puncture in Central Bolivia which we repaired, then 13 Km later another which was unrepairable. Then a couple of hundred Km (on the same surface which had given us 2 punctures in 13 Km) to the nearest village. They were unable to help, so another couple of hundred Km to a town where we were able to buy a new tyre (hauled in on "chicken run 'bus" from La Paz in two days). It was a little unnerving, as you say, however worked out OK.
PS: 42 deg C when we changed the unrepairable tyre...
912137
