75 series landcruiser Ute slipping out of 4wd
Submitted: Sunday, Sep 06, 2020 at 21:04
Harrison B
I have recently bought a 98 75 series diesel Ute 1hz, I’m having trouble with getting the car to stay in 4wd. When I have stopped the car moved the car into 4 Low it won’t grab and stay there it slips back into neutral. Both 4 high and low engage fine and drive perfectly in then however I’m just having trouble with the car slipping back into neutral
Reply By: RMD - Sunday, Sep 06, 2020 at 22:41
Harrison
DO you mean, while stopped and select 4WD it immediately slips out of 4WD before you move anywhere? That is how it reads! If so I would look at the gearbox mounting and centralization of the stick in the floor pan hole. If near the edge or the rubber boot is stiff or awkwardly compressed when selecting it may be simply pushing back because or either engine/gearbox mounts or the boot and stick position. I has to relieve a slight amount of floorpan on my HJ61 as it became/was made close to one side of the stick hole. Loosening GBox mount and repositioning fixed the problem. Maybe that!
Can be a Transfer case wear problem too.
633302
Reply By: Member - Serendipity(WA) - Monday, Sep 07, 2020 at 09:43
Having owned one of these a few things come to mind.
First if it pops out of gear but you can hold the gear stick in gear there is a thing called the 'dedent spring'. A small spring pushing a ball bearing into place that helps keep the gear in place. Just google 'landcruiser dedent spring' you will find your answer.
I also found the hi/low gear stick mounting bracket gets bent out of shape. I had to make up a third bracket that goes off at a right angle, back to a housing bolt forward, that holds the gear stick mounting bracket from bending. This was needed because it became harder and harder to change into low gear. The mounting bracket had bent backwards and would not let me follow through far enough to engage low range.
Next if it pops out of gear but you can't hold it in place - bad, very bad. This is a bit past my knowledge but I think it has something to do with worn shims in the gear box. If you change your gearbox oil and metal filings come out. Bad.........
633309
Reply By: Member - DOZER - Monday, Sep 07, 2020 at 09:56
under the floor there is a bracket that can move which is bolted to the transfer case. this movement wont allow the lever to engage low range properly,
check it out, loosen it and move gear stick into low then retighten, should fix it up.
633310
Reply By: Harrison B - Monday, Sep 07, 2020 at 19:13
Thanks for your replies, sounding like it would be the issue with the dedent spring. I am able to hold the car in 4wd Low and drive perfectly fine and same goes with 4 high however the car won’t hold itself there
633327
Follow Up By: RMD - Monday, Sep 07, 2020 at 19:35
Harrison
If you have any understanding of gearboxes and transfer cases you will know the DETENT ball and spring is there to confirm and hold in position with normal operation. Until you thoroughly
check the boot/stick centralisation clearance in the floor pan AND the linkage position of holding the stick in the floor pan as others have instructed you to do, any consideration of a detent problem is further down the track. If everything above is ok and correct AND you have to physically hold it in position with some degree of force to hold engagement it cannot be the detent, but a worn selector fork or dog clutch edges which are forcing it out of gear position. Have a reconsider of what you believe before it gets costly for you. You may be able to save some $$$$$'s if investigating sensibly.
910313
