Shade cloth under roof cargo rack
Submitted: Monday, Jan 27, 2020 at 11:43
ThreadID: 139597 Views:7217 Replies:5 FollowUps:0
Hi, I’m getting a roof cargo rack on my Iveco Daily . It’s going to have mesh like security door as the floor of the rack. Anyway I was thinking of maybe getting a piece of shade and putting it under the floor just to get a bit more shade in the heat of the day. Just wondering if others have done it? I remember seeing old vans with a roof built on top for that reason I imagine. Anyway, keen to hear if anyone has done similar. Thanks
Reply By: Gbc.. - Monday, Jan 27, 2020 at 17:04
They were called tropical roofs way back when.
AnswerID: 629747
Reply By: Norm F - Monday, Jan 27, 2020 at 17:09
I put a sheet of 2/3 mill ply from Bunnings over floor of mine to create shade
"the only thing constant in my life is change"
AnswerID: 629748
Reply By: RMD - Monday, Jan 27, 2020 at 17:17
Shade cloth is just that, shade, better to have enough to block out the rays and still have an airgap above the rook of the Iveco. Thin Ply on top may be a solution as it also prevents items going through the mesh. And shade too.
AnswerID: 629749
Reply By: Member - McLaren3030 - Tuesday, Jan 28, 2020 at 07:41
Hi Trevor G5,
Sounds like a good idea in principle. An issue I see with “flexible” covers under the floor of the roof rack is that it will trap debris like leaves & dust, and will become heavy if it rains or gets wet, it may then sag and tear.
On the other hand, hard covers placed on top of the floor of the roof rack then restricts your tie down points to the front, back & side rails only. Of course you could add tie down anchor points to the ply wood, although not sure how strong these may be. Would be interested in the experience of others that have done what you are suggesting.
AnswerID: 629762
Reply By: HKB Electronics - Thursday, Jan 30, 2020 at 09:48
We get the occasional rocks landing on the roof o our Prado, I would be concerned as such of the same building up on top of the shade cloth as mentioned above. Also if you get them trapped between the shade
cloth an the roof would not be good.
AnswerID: 629798
