76 series landcruiser
Submitted: Saturday, Jan 18, 2020 at 11:42
spaanderman65
Hey im looking at purchasing a car. Is a 2011 76 series cruiser with roughly 180000 kilometres on it a safe buy if its been looked after?
Cheers regards callum
Reply By: swampy - Saturday, Jan 18, 2020 at 13:24
HI
Cruisers are no different to other vehicles if driven hard , still wear out . The difference is if given a gentle life 300,000--400,000km is not outa the question .
A FULL
check over is needed
tyre wear front end
check and rear
suspension check
leaking hubs
wheel bearings serviced
brake condition
brake fluid flush
shockers mounts /leaking
tailshaft condition
eng g.box mount
drive line leaks
cooling system service and pressure
test
power steer
check
clutch perf
gearchange perf
pulling when driving and or under brakes
brake pedal feel
steering wheel vibration
As with any car Air con evaporator needs a clean to insure good performance
This is just a few areas to
check over
629576
Reply By: AlbyNSW - Saturday, Jan 18, 2020 at 17:12
180k isn’t much and would be fine depending on how the vehicle has been looked after.
629580
Reply By: swampy - Saturday, Jan 18, 2020 at 20:27
Driven poorly cruisers canbe destroyed in about 2-4 years . 100% offroad dirt road application .
Get the vehicle checked over at your RACV RAA RACQ etc if your serious .
Never take peoples word ,the repairs if you get caught out will cost a lot potentially .
629584
