Wednesday, Jan 15, 2020 at 11:47
Well Alloy I did look at the history and just as I thought you are wrong!!again!
"History
The first lead-acid gel battery was invented by Elektrotechnische Fabrik Sonneberg in 1934.[6] The modern gel or VRLA battery was invented by Otto Jache of Sonnenschein in 1957.[7] The first AGM cell was the Cyclon, patented by Gates Rubber Corporation in 1972 and now produced by EnerSys.[8] The cyclon is a spiral-wound cell with thin lead foil electrodes. A number of manufacturers seized on the technology to implement it in cells with conventional flat plates. In the mid-1980s two UK companies, Chloride and Tungstone, simultaneously introduced 10 year life AGM batteries in capacities up to 400 Ah, stimulated by a British Telecom specification for batteries for support of new digital exchanges. In the same period, Gates acquired another UK company, Varley, specialising in aircraft and military batteries. Varley adapted the Cyclon lead foil technology to produce flat plate batteries with exceptional high rate output. These gained approval for a variety of aircraft including the BAe 125 and 146 business jets, the Harrier and its derivative the AV8B, and some F16 variants as the first alternatives to then standard nickel-cadmium (NiCd) batteries.
Every battery manufacturer also gives out the temperature range its batteries should operate at for longevity. All of them do not like heat!!
CUT AND PASTE FROM A RESPECTED BATTERY
FORUM....
'Heat is a killer of all batteries, but high temperatures cannot always be avoided. This is the case with a battery inside a laptop, a starter battery under the hood of a car and stationary batteries in a tin shelter under the hot sun. As a guideline, each 8°C (15°F) rise in temperature cuts the life of a sealed lead acid battery in half. This means that a VRLA battery for stationary applications specified to last for 10 years at 25°C (77°F) would only live 5 years if continuously exposed to 33°C (92°F) and 30 months if kept at a constant desert temperature of 41°C (106°F). Once the battery is damaged by heat, the capacity cannot be restored.
According to the 2010 BCI Failure Mode Study, starter batteries have become more heat-resistant. In the 2000 study, a rise in temperature of 7°C (12°F) affected battery life by roughly one year; in 2010 the heat tolerance has been widened to 12°C (22°F). Other statistics reveal that in 1962, a starter battery lasted 34 months; technical improvements increased the life expectancy in 2000 to 41 months. In 2010, BCI reported an average age of 55 months for starter batteries, with the cooler North attaining 59 months and the warmer South 47 months. Colloquial evidence in 2015 revealed that a battery kept in the trunk of a car lasted one year longer than if positioned in the engine compartment.
Why does your Nokia last 3 times longer? BECAUSE IT DOESN'T EVEN HAVE THE CAPABILITY TO DO 5% OF WHAT THE I-PHONE DOES!!
904496
