Autofridge Replacement in Kimberley Kamper
Submitted: Thursday, Oct 10, 2019 at 12:13
Member - Ross N (NSW)
My aging Autofridge has failed permanently. An Engel 40 fits in the space but I was hoping for a larger fridge.
The specification for a number of fridges I have looked at don’t fit within the space.
Has anyone found a satisfactory replacement ?
Ross Nielsen
Reply By: RMD - Thursday, Oct 10, 2019 at 15:28
Ross
If height isn't the problem:
For Engel 40 litre there used to be a height sleeve which fitted to top of fridge and extended the cool space a few more litres. Seeing it is a caravan that may be an option for you if Engel still makes them. Alternatively, I have seen an owner built/made sleeve with insulation and sealing at the join and the lid simply made to fit the produced sleeve, along with a catch to hold it shut.
The sleeve I saw had a formed sheet aluminium outer and lid, and an inner of acrylic of white acrylic sheet heated and bent around a former which was same size as the fridge internals.
The gap between the inner and outer was filled with spray expanding foam and the expanded excess trimmed off. Seemed to work
Having removable sleeve suited lesser capacity or as a freezer and with it more cool volume.
628102
Follow Up By: Member - John - Thursday, Oct 10, 2019 at 17:39
These are still available, but add an extra 250mm to the height.
902385
Reply By: Bob Y. - Qld - Thursday, Oct 10, 2019 at 15:38
I have an Ironman 30L fridge that looks to be about the same footprint as an Engel 40L. Ironman also sell 40 & 50L models, same footprint but each a bit taller.
Really quiet fridges, compared to an Engel,, but a little power hungry I thought. I’m happy with the 30L model. Think they’re a re-badged Waeco?
628103
Reply By: Phil G - Thursday, Oct 10, 2019 at 16:08
A 60Litre Kings might fit if you have a couple of extra cm height and width over the engel. I have both these fridges and can interchange them on my vehicle's fridge slide. And the Kings appears to use less power!!
510H x 410W x 660L mm
60L Kings
628104
Reply By: Member - McLaren3030 - Friday, Oct 11, 2019 at 15:31
Ross,
We had a
Kimberley Kamper Limited, our 60 Ltr Engel fitted in the fridge slide without any problems. What model & how old is your
Kimberley Kamper?
628116
Follow Up By: Member - Ross N (NSW) - Friday, Oct 18, 2019 at 16:26
Thanks Macca
My KK IS A 2006 Platinum
Ross
902500
Reply By: sub - Friday, Oct 11, 2019 at 18:15
National Luna 50
628119
Follow Up By: Member - Ross N (NSW) - Friday, Oct 11, 2019 at 21:06
Thanks sub
I will
check measurements
Ross
902409
Reply By: Member - lyndon NT - Sunday, Oct 20, 2019 at 09:18
Ross
Have the electronics failed? If the box is good I think just about everything excluding the electronic control can be replaced.
Compressor, thermostat, fan (if yours has one), can all be replaced.
I have a "dead" 73 litre much loved Auto fridge. I may throw some money at it and try to get it fixed one day. Our problem is living in
Darwin. A $600 fix is a $1000 in
Darwin and even then your never sure it will get done properly.................
There just aren't any fridges of comparable standard that I know of.
Lyndon
628224
Follow Up By: Member - Ross N (NSW) - Sunday, Oct 20, 2019 at 11:53
Thanks Lyndon,
The refrigerant had leaked into the case which is sealed.
The fridge has gone to wherever dead fridges go.
902517
