Suspension question
Submitted: Sunday, Apr 14, 2019 at 19:31
LAZYLUX16
Wondering what to look for on secondhand 2010 campervan it has Single Axle Simpliticity
Suspension Leaf Springs and looks like leading arm, attached to a very solid beam. .CV looks like done hardly any off road wor it actually looks new. . But no expert on
Suspension and want to know what to look for. Thanks
Reply By: RMD - Monday, Apr 15, 2019 at 12:36
LAZYLUX16
While it probably works quite
well, I am puzzled as to why an arm type
suspension on a single axle doesn't use a coil spring, and instead has the arm (trailing or leading) but also attached to a leaf spring. It all means more complication, not Simplicity at all.
A mate has Simplicity dual axle on his 3T van and it works
well, but quite heavy.
I aligned the wheels for him a while back, as the standard setting seemed to have moved causing toe in wear on LHS wheels. Since done 20,000km with normal wear.
Your system probably has adjustments for camber and or toe in/toe out too and possibly should be checked for correct alignment before using it to preserve tyres.
I do not know what settings or tyre wear pattern exists and so a person who can decipher wear, if present, ie, cause /effect, to make the correct adjustment alterations may be required
624963
Reply By: swampy - Monday, Apr 15, 2019 at 22:03
Take a picture of said
suspension and compliance plate then send to simplicity.
Your
suspension could possibly notbe the current version .
624972
