Prado to Ranger Wheels
Submitted: Sunday, Sep 16, 2018 at 11:19
Member - Scruffy
Good morning all, This one for the rim and tyre gurus. I have changed from 03 Toyota Prado to 18 Ford
Ranger. Both Have 17" rims so can I use my extra spare from the Prado on The
Ranger? Looking forward to your answers.
Reply By: Member - nick b boab - Sunday, Sep 16, 2018 at 11:41
your talking about a 2nd spare , why don't your try it on the front 1st see if it clears all your
suspension parts doesn't hit brake caliper etc and has a similar backspace
the chances of you needing it are slim , are the tyre size the same ?
621244
Follow Up By: Member - Scruffy - Sunday, Sep 16, 2018 at 12:01
Thanks Nick, Tyre sizes will be the same but I was concerned about offset and thought some one might have the technical species.
Scruf
893762
Reply By: IvanTheTerrible - Sunday, Sep 16, 2018 at 11:57
Prado run 0 or 25Positive offset depending on the exact date and
Ranger run a 13 Positive offset so I'd say no
621245
Reply By: Member - Boobook - Sunday, Sep 16, 2018 at 12:01
Reply By: RMD - Sunday, Sep 16, 2018 at 14:16
Scruffy.
It is not hard to measure the rim widths and determine the centre of it. Measuring from the inner face of both rim types to their centreline of rim will immediately reveal the offset. Trying to follow the above gobbledy gook of offsets may not help.
Of course "fit check" the rim as advised above as that will ensure you know caliper and hub face compatibility. The rim inner dia should also be considered too, because it may prevent fitting the rim on either front or back or both.
Not many people will know ALL factors and unless aware of all measurements you may have a problem.
621249
Follow Up By: Member - nick b boab - Sunday, Sep 16, 2018 at 18:57
Agree the only way to know for sure is to try it and as long as every thing clears , keep it in mind it's a 2nd spare ??
893769
Reply By: Member - DOZER - Monday, Sep 24, 2018 at 20:01
the prado spare will stick out an inch further. if it doesn't fit, I have a brand new tyre spare 16 inch thou, you can have for free
621367
