Track Report - Balgo to Kiwirrkurra Track
Submitted: Monday, Jul 09, 2018 at 19:16
IvanTheTerrible
We completed this track 5th July 2018
I'll do this in sections from Balgo down.
Balgo to the abandon tower is a half decent track with mild corrugations. There is an aviation fuel dump with Jeta-1 fuel at the tower so I assume the road has some use
Tower to the Yanga Yanga
gate is fairly corrugated but not to bad.
The
gate to the the abandoned Yang Yanga village is the best bit of road on the whole trip being smooth and flat with no corrugations till just before the village.
After Yanga Yanga the road turns into a goat track that is corrugated with moderate to major errosion and a lot of diversions. It is also very narrow with a fair proportion lined with bushes both alive and dead that hit everything on our Dmax even with the mirrors in. The condition deteriorates the further south you go with a few very rough and steep creek crossings. There also a few steep, erroded descents off some raised rocky areas. We struggled to get 30-40kph on the good bits. After you pass the tank with the bath the track starts to improve but is still very narrow all the way to
Lake MacKay.
The track around the lake is fairly rough and undulating but does have some good sections and this continues all the way to the turnoff to the
mine.
From the
mine to
Kiwirrkurra the track is a mixed bag. It is generally good but there are a lot of very soft sandy sections and some rough rocky sections. All the
sand dune crossings have been capped with clay and gravel so they present no problems. We towed a trailer and if anyone wanted to do the same I'd suggest on with good articulation at the hitch. Also be aware that the track does deviate from what is marked on the map in a few
places.
Reply By: Member - Stephen L (Clare SA) - Monday, Jul 09, 2018 at 19:28
Hi Ivan
Sounds like you had a great time out there.
You should put some images up so we can all envoy your trip.....lol
What maps were you referring to as all maps that I have studied show no tracks at all in many parts of the drive. Even the latest
EOTopo shows not tracks in the central section.
620064
Follow Up By: IvanTheTerrible - Monday, Jul 09, 2018 at 20:23
EOTopo. Even some of the tracks marked are different.
892383
Follow Up By: Member - Stephen L (Clare SA) - Monday, Jul 09, 2018 at 21:09
Thanks for that Ivan.
892385
Reply By: IvanTheTerrible - Wednesday, Jul 11, 2018 at 19:09
Map inconsistency. Dark line is the actual path.
And this is the bit that is missing.
620090
