Hard shell roof top tent not fully opening
Submitted: Friday, Jun 22, 2018 at 21:40
Rod W6
Today I installed a new hard
shell roof top tent (all excited) only to find the front/thin end will not lift up and/or stay up/open (excitement now deflated). I am currently dealing with the supplier for a resolve. But I thought I would post here in case anyone else has had a similar issue. I suspect a faulty gas strut/s
Rod
Reply By: Member - Boobook - Saturday, Jun 23, 2018 at 09:13
Rod, I guess it would be more help if you posted the brand / model.
619762
Follow Up By: Rod W6 - Saturday, Jun 23, 2018 at 10:34
I have deliberately left the brand/make out as at this stage its not the issue.
892075
Follow Up By: Hoyks - Saturday, Jun 23, 2018 at 14:02
But having some idea what design you're working with might help.
892078
Follow Up By: Leigh H - Tuesday, Jun 26, 2018 at 19:00
May I assume it is not a wind up unit with crank handle to raise it. If it is then the connecting chain might have come adrift from the non crank end. Easy fix if it's the case.
892133
Follow Up By: Rod W6 - Tuesday, Jun 26, 2018 at 21:00
Hi Leigh. Its a gas strut version. The supplier is sending replacement struts.
892136
