Cub Supermatic Drover 2007 - Wheel bearings and shocks
Submitted: Thursday, May 24, 2018 at 09:57
Trekabout
Hey folks just after a little advice if possible please.
Heading up to
Birdsville for the BRB in a few weeks time and want to change out the wheel bearings and shock absorbers on our 2007 Cub Supermatic Drover.
Can anyone advise what wheel bearings this age Supermatic Drover would be running (currently has Toyota Landcruiser rims so I'm guessing Toyota bearings but a p'n would be great ) and what a suitable HD shock absorber replacement would be given we have a leaking seal in one unit (p/n would also be great). Going to do the swap out ourselves but living in a rural location want to order the parts in rather than run around and have the a) Cost associated with others doing the job and, b) Don't have the time to run around looking for others to do the work given we're an hour away from any main town or service centre.
Thanks very much.
Reply By: splits - Thursday, May 24, 2018 at 10:21
All bearings and cones have a number on them. They are deeply embedded in the metal around the outer edge and can't wear off. Have a look at yours and buy the same ones.
As for shocks, they should be properly matched to
the springs. I would look at the websites for the major manufacturers and see if they have a customer information number. Most companies in just about any field do. Some have phone numbers while others use email. This is just one example.
KONI
Contact them and see what they say.
619111
Reply By: Nomadic Navara - Thursday, May 24, 2018 at 11:46
They certainly will not have Toyota bearings (unless Toyota use generic bearings.) I suggest you contact
Cub Campers in regards to the shockers and what hubs are fitted to their campers.
619116
Reply By: RMD - Thursday, May 24, 2018 at 12:13
Trekabout
Just because a hub has toyota 6 stud pattern or even a 5 stud pattern does not mean the hub bearings are anything like the size of Toyota hub bearings.
Any reputable bearing has the numbers on both the cup and cone edge as mentioned above and if removing them you can read the numbers.
I also guess the bearings will not be same as Toyota at all, one look at the hub dia will indicate that, uness the same outer dia as a Toyota hub it is unlikely the bearings are the same. Most caravans are not the same.
Make sure you buy reputable bearings names and not cheaper offerings commonly supplied. Not sure what you mean, "change them out" and American term, Aussies just "replace" them.
If the bearings in the hubs are good quality and not damaged or brinelled or chipped or scored, then replacement probably isn't required. You just have to
check the whole surface of the perfectly clean cone whilst looking through the rollers to see any degradation. Cups are easily inspected.
Shock replacement can be done by internet searching of the type of end fixings and the closed and open stroke length. Same or similar shocks which work
well will suffice, you can be sure the manufacturer of the Cub never matched the shock performance to
the springs to any great degree.
Then when you hit town you will know which bearings you need and also the shock absorber description data too.
619117
Reply By: Member - Stephen L (Clare SA) - Thursday, May 24, 2018 at 14:35
Hi Trekabout
The first thing you need to know is are the inner and outer bearings the same?
Some use different size bearings, while my Ultimate use the same size inner and outer Ford bearings.
Living in the country, we have many advantages over city folk, as all I have to do is walk down the street and go into one of out rural machinery distributors and take a sample of the bearing I need. No waiting around and dozens in stock.
I use the principal that if anything is going to happen, it will be me and always carry 8 bearing, tools and grease so in the event of trouble, it is an easy roadside fix.
Have a great time in
Birdsville.
619120
Follow Up By: Shaker - Thursday, May 24, 2018 at 19:46
I prepack the bearings with grease & then vacuum pack them.
891336
Reply By: Crusier 91 - Thursday, May 24, 2018 at 21:42
Off topic, have you thought about rear window protection? unless you dont have one.
619128
Reply By: Bob Y. - Qld - Thursday, May 24, 2018 at 22:15
Shockies should have a part number stamped onto the stone guard, or perhaps down near the lower mount, Trekabout.
619131
Reply By: Malcom M - Friday, May 25, 2018 at 06:13
As said the bearings have numbers on them. Any bearing
shop can supply them.
Cub currently use custom made shocks by Rox Shocks.
The manufacturer is Ateco EQuipment
ProductSupport@ateco.com.au
No idea if they were fitted to your trailer though.
You don't just wack any shock in. You have to match the dimensions, mounting system, performance etc. Some shocks have 'over extension' limits built in others don't.
Ring Cub and find out what should be in there and take it from there.
619135
Follow Up By: Trekabout - Friday, May 25, 2018 at 14:27
Thanks for the
feedback re the shocks - Apparently they are 'Custom made' for Cub and are available at the cheap price of $160 each supply only. Think I'll make some calls to Ateco and see how that works for me. Cheers Andrew
891359
Follow Up By: Malcom M - Friday, May 25, 2018 at 16:37
Jeez Andrew. Gobsmacked with that price!
Ateco aren't a lot of help as they are customs so will likely refer you back to Cub.
They can however tell you if there is anything special about them so you can explore alternatives.
My trailer has independent
suspension and there is no checkstrap arrangement to prevent the arms dropping down and releasing the coils.
Ateco told me that the shocks have beefed up guts to provide this function which helps explain the cost if you have independent.
Malcom
891367
Reply By: Phil B (WA) - Friday, May 25, 2018 at 07:20
Its probably safest to take off the components and take them to a bearing or shock absorber supplier. Then you're not going to get it wrong.
Not much good going with the old 'I think its Ford bearings'.
I'm unaware were you live, over here in the West we have trailer parts supplier Martins Trailer parts; the bearing quantities they buy enables them to sell bearings, seals etc. at great value prices.
619136
Reply By: Member - McLaren3030 - Friday, May 25, 2018 at 09:19
He Trekabout,
Contact Cub, tell them your Chassis number, they should be able to look up in their records and provide you with all the relevant data of your camper.
619144
Reply By: Dean K3 - Friday, May 25, 2018 at 10:22
As mentioned by Phil B pull them off take them as samples to a bearing supply company and they can then investigate all bearing seals will have a size/part number on them just case of indentifying them properly.
I tried to get some info from a
suspension supplier used commonly on caravans etc, all they could advise was take it apart and then measure up and then they could advise accordingly
So makes one wonder about their spare parts knowledge, if I could tell them the exact model used on caravan/camper .
619148
Follow Up By: Nomadic Navara - Friday, May 25, 2018 at 10:42
Quote "I tried to get some info from a
"So makes one wonder about their spare parts knowledge,"
The manufactures make several load capacities of their suspensions. They are likely to have different bearings on each of the different capacities. If you don't give them the exact
suspension model they they can not tell you which bearings yours has fitted.
Your comments regarding their knowledge is unwarranted.
891353
Reply By: Member - Howard P (WA) - Friday, May 25, 2018 at 14:16
You might want to consider replacing the bearing hub seals as
619155
Reply By: Trekabout - Friday, May 25, 2018 at 14:25
Thanks for everyone's
feedback - Cub have kindly provided the P/N for the bearings etc which I can get locally and a new set of shocks are being posted through to me next week by their service team. For those that are interested the bearing P/N for a 2007 Cub camper with 45mm stubs are Inner - LM297449/10, Outer LM67048/10 and the grease seal is 30400. All parts are available via Alco as
Regards,
619156
Follow Up By: Shaker - Friday, May 25, 2018 at 16:25
Make sure that you use 2 piece marine seals.
891364
Reply By: Trekabout - Friday, May 25, 2018 at 14:48
Oh yes and the Shocks are made for Cub by Ateco Products who won't/can't supply a P/N for the shock absorbers as you have to go directly to Cub to purchase them at $360 a pair plus delivery!
619157
Follow Up By: garrycol - Friday, May 25, 2018 at 16:36
Just take a sample to a car
suspension place and they will match them with something suitable.
891366
Reply By: Member - Darwin Dave - Saturday, May 26, 2018 at 10:13
Good morning Trekabout,
Pull the bearing out and
check numbers before you buy new ones. LM 67048/10 is a inner Holden bearing which will only fit 39mm round or 40mm square axle. 45mm square axles use Ford bearings.
Regards,
Dave
619169
