Sunday, Mar 18, 2018 at 13:43
Hi Janet,
The main site menu is located at the top left of this website - it is visible from every page. If you click this (the word Menu) it will drop down all the labelled section of this website. The list is in alphabetical order... Articles,
Blogs,
Classifieds....etc to
Treks. If you click
Treks it will open 2 sections, labelled ExplorOz
Treks, and User
Treks. Click ExplorOz
Treks from here.
ExplorOz Treks in Menu
The way you've done it, is also fine. Every page of the site has Quick Links section in the black panel at the very bottom of the every page of the site. You've gone into
Treks this way.
Both take you to the same page of ExplorOz published
Treks.
So once on the Trek Notes page, you are given a few different ways to browse for
Treks.
1. the open search box let's you type in the name of what you're looking for.
2. The next options are State
3. the next is Map.
Browsing options in Treks
If you click State, you can then select South Australia, and then see a list of all the names of
Treks we publish for that state and then you can select Anne Beadell, and/or
Maralinga Range Tour. If you click Map you'll see lines across a map of Australia showing all our
Treks so you can zoom in on an area and click a trek line route - without knowing its name you can find it visually.
889391
