coast to coast panel reading full
Submitted: Thursday, Jan 18, 2018 at 20:01
Johnnykluger
Hi just purchased a used jayco swan I had both tanks emptied to save weight whilst towing back from interstate.the jayco has twin tanks and a meter shows when the tanks are empty yet the second tank is reading full on the panel why would this happen .any ideas as to what’s going on?
Reply By: Peter_n_Margaret - Thursday, Jan 18, 2018 at 20:47
Crud on the level terminals in the tank.
Pull it out and clean it.
OKA196 motorhome.
616184
Follow Up By: Johnnykluger - Thursday, Jan 18, 2018 at 21:13
Where would that be ?
887466
Follow Up By: Peter_n_Margaret - Thursday, Jan 18, 2018 at 21:18
In the side of the tank somewhere with about 5 wires going to it.
887467
Reply By: Athol W1 - Friday, Jan 19, 2018 at 07:46
Johnnykluger
Have you tried just switching the water pump ON via the switch on the panel, as the gauges only read water level when the pump is live (not pumping), and retain whatever level was recorded the last time pump wiring was active.
Athol
616193
Follow Up By: Member - William B (The Shire) - Friday, Jan 19, 2018 at 10:18
I agree with Athol,
I have also popped the panel off and disconnected the wires in the back to reset if turning on the water pump doesn't do the job.
William
887478
