OziExplorer file conversions
Submitted: Friday, Jul 21, 2017 at 13:55
Life Member - Duncan W (WA)
Afternoon all, is it possible to convert an Ozi ce TRB file to a PLT file? Unfortunately my track file log on my HEMA wasn't set to file my daily log but appended each day.
Dunc
Reply By: Dean K3 - Saturday, Jul 22, 2017 at 17:21
I searched hi n low google and ozi with no avail.
Best to contact Des
Newman himself and ask him that question.
612668
Reply By: gbc - Sunday, Jul 23, 2017 at 15:18
Have you tried gps babel? It is a free download and can convert most gps files.
612676
Follow Up By: Life Member - Duncan W (WA) - Monday, Jul 24, 2017 at 10:23
Thanks gbc downloaded the programme unfortunately it recognises every GPS file type under the sun but not Ozi ce files.
Dunc
883035
Follow Up By: gbc - Monday, Jul 24, 2017 at 11:12
Bugger. Sorry about the bum steer.
883036
Follow Up By: Life Member - Duncan W (WA) - Monday, Jul 24, 2017 at 12:29
Wasn't a bum steer in so much as I've now got a very handy little programme sitting on my computer.
thanks
Dunc
883037
Reply By: maurice b - Sunday, Jul 23, 2017 at 19:25
You need to Export track Tail to File...My WinCe days passed a long time ago . However booted up my 9 y/o HP 312 running OZi Ce.
The steps are File/Tracklog/ Export Tracklog to file , Name the file, should be default .plt. ''save it as a .plt'' . After you save it, the file will be stored with that name in your Oziexplorer Data folder. It may only be a few hundred meters long, depends on how you configured your device . Not sure on
the steps on a Hema Hn but would be similar different buttons.
"Export track tail to file"
612682
Follow Up By: Dean K3 - Monday, Jul 24, 2017 at 18:13
Thanks for tip, pity I can't read the 7 inch screen (indash) enough to use functions on CE properly. But then lappy is too big to have bouncing away on floor either.
Easy to read for "current location" as a moving map, so begs question is a 8-10 inch tablet capable of running oziexplorer had a look at usual suspect (officexxxx) as lappy will die but rep says it not powerful enough to run external hard drive or programs like oziexplorer
So has me wondering what I need to replace laptop with in future -already using external usb keyboard as laptop has stopped working despite being replaced 18 months ago
883045
Follow Up By: Member - David P (WA) - Monday, Jul 24, 2017 at 23:37
Hi Dean
Don't give up on your Oziexplorer CE just yet especially if all you need is to make the writing bigger. These are the settings I use for my 7 inch touch screen.
- open Oziexplorer on the device
- Config - general settings
- sys2 tab
menu font size = 9 Tick box adjacent to auto adjust
dialog font size = 14
toolbar size = 24
menu bar = 1
keyboard size = 6
883057
