2004 patrol blown motor
Submitted: Tuesday, Apr 18, 2017 at 12:25
fence
Son in Laws vehicle. .very clean . 170000ks.
Does anyone know if it is feaseable to replace the 3 ltr turbo engine with a 4.2
thank you,
bruce
Reply By: Deejay - Tuesday, Apr 18, 2017 at 13:53
Bruce. I strongly recommend you join a Patrol
forum. I'm a member of Patrol4x4 and it has a ton of information about your question. Suggest you do a search first and if you don't find what you're after, post your original question (but point out you're a newby). I myself have some knowledge of the dilemma but you best hear it from the other guys who have been through this problem. Good luck, Deejay.
610311
Follow Up By: Gundarooster - Tuesday, Apr 18, 2017 at 14:45
Strongly Agree you should join the Patrol
forum, but, I had a 2006 TD4.2 burst a heater hose and seize before I figured out what was wrong, cost $20k for a new long motor and new turbo fitted and I already had all the ancillary bits available so I reckon no change out of $25k unless you do all the work yourself.
I believe there is a Yank V8 Diesel that is a common swap for a 3.0L grenade and will be about the same or less to do and more power/torque at the end of the project..
Happy to provide more info on my experience.
Gazza
880223
Reply By: Member - Ian C26 - Wednesday, Apr 19, 2017 at 20:28
Bruce,I strongly advise the Patrol
forum, I used to have a td 4.2td,and if you have look at thread 134581 BLOWN TURBO, mine was a water pump which seized my motor, and unfortunately,I had been quoted anywhere between $15,000- $20,000 and that`s money I didn`t have....sold the
shell $ 3,000 the very best I could get, change your water pump too, a company make one just for Patrols,because of this problem $ 500 but
well worth it I reckon,they have a website, good luck.
Ian.
610361
Follow Up By: David T6 - Wednesday, Apr 26, 2017 at 17:07
Another not so common replacement is a Toyota HDFTE motor. This is the factory turbo intercooled motor.
880509
